I put everything back and the car started OK...I tuned the carbs as per the "Book"...on taking the car for a run, it runs aweful..lack of power, back firing...
I pulled the air filters and went thru the tune again and still the car runs bad...I lookede at the plugs and very sooty, I leaned the jets but made no difference...any ideas would be helpful..
Prior to the valve sticking the car ran fine, so I assume the timing is OK...
