Head gasket
Jasonking
Head gasket
Post by Jasonking »
Hiya all, is it viable to use any type of gasket sealer on new head gasket? Does anyone use a particular type with success?
Has thanked: 59 times
Been thanked: 15 times
Re: Head gasket
I'm loathed to as most have a sealant on them that's heat activated. Putting anything else on them can interfere with that.
Having said that, when I have made annealed solid copper head gaskets, I use spray on Hylomar on them.
atm92484
Re: Head gasket
Post by atm92484 »
I'll second Spider - depends on the headgasket but if I do it is spray Hylomar.
Jasonking
Re: Head gasket
Post by Jasonking »
Can you use spray Hylomar on today’s copper gaskets? And do you coat both sides?
Rolandino
Re: Head gasket
Post by Rolandino »
I would never spray anything on a copper head gasket. Leave it in half an inch of water for 3 hours and then fit.
I hate electric cars !
swifty
Re: Head gasket
Post by swifty »
I’ve been using the Minispares copper head gasket with wellseal and have had not a single problem … Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Jasonking
Re: Head gasket
Post by Jasonking »
And is that using Wellseal on both sides of the Minispares gasket?
swifty
Re: Head gasket
Post by swifty »
Yes on both sides , once applied leave for 15 minutes before fitting . ,,,, Shirley
Porsche 997 turbo S
I am from Essex
Jasonking
Re: Head gasket
Post by Jasonking »
Cheers, thanks a lot😀
MiNiKiN
Has thanked: 18 times
Been thanked: 9 times
Re: Head gasket
Post by MiNiKiN »
Rolandino wrote: Thu Jun 13, 2024 4:35 pm I would never spray anything on a copper head gasket. Leave it in half an inch of water for 3 hours and then fit.
What is the reason behind this custom?
Rolandino
Re: Head gasket
Post by Rolandino »
Its supposed to swell up the material in betweeen the copper sheets. It seals better
