It is undoubtedly a part of an original BMC Mini luggage set.Old English White wrote: ↑Tue May 28, 2024 3:38 pm Is there actually any evidence at all to suggest that it is anything to do with Minis or BMC?![]()
I'll try & find some pictures.
Yes, it looks too bright and shiny to be Glyptal, although what the point of painting those surfaces is I don’t know. Plenty of oil on top usually!Polarsilver wrote: ↑Fri May 31, 2024 12:01 pm If i fitted that Head i would be thinking as to when the Red Paint came off & damaged my Crank Bearings or Blocked up the Heater
Got to £1000 and pulled from eBay. The buy it now was £1600
Makes you wonder if it will actually get fitted, or just be kept as a memorabilia item ?
Looks like an original car despite the issues described in the listing.WMU 211G wrote: ↑Fri May 31, 2024 12:35 pm Mk2 S project with A+ engine fitted...
https://www.ebay.co.uk/itm/395437985533 ... SwLTlmWJi9
yes ...with lots of "period" repairs, amazing they are still around to findPete wrote: ↑Mon Jun 03, 2024 10:44 amLooks like an original car despite the issues described in the listing.WMU 211G wrote: ↑Fri May 31, 2024 12:35 pm Mk2 S project with A+ engine fitted...
Someone picked a bargain!rnp68 wrote: ↑Sun Jun 09, 2024 5:55 pm Early H4 carbs on a series inline manifold
https://www.ebay.co.uk/itm/116206389277 ... media=COPY
Do you really think they did get a bargain?MiNiKiN wrote: ↑Mon Jun 10, 2024 8:44 amSomeone picked a bargain!rnp68 wrote: ↑Sun Jun 09, 2024 5:55 pm Early H4 carbs on a series inline manifold
£175.00 was the buy it now price on this item. 1500 is the set in the FS-section of your forummk1 wrote: ↑Mon Jun 10, 2024 12:08 pmDo you really think they did get a bargain?MiNiKiN wrote: ↑Mon Jun 10, 2024 8:44 amSomeone picked a bargain!rnp68 wrote: ↑Sun Jun 09, 2024 5:55 pm Early H4 carbs on a series inline manifold
A fairly manky set of H4's with Minispares ram pipes, tiny T1 float chambers, with most of the choke linkage missing, all on an MG100 Manifold for £1500 !!
The last real set I sold, was less than 1/2 that!
Yes the carb bodies are more or less identical and it’s all the parts that bolt on make them L or R
