I will defenately reinforce the fixing points. And the hand made seams are strong enaugh too.hanlminiman wrote: ↑Mon May 13, 2024 7:54 pm From personal experience in a competitive accident I suggest you make sure the Fixings points are very strong and secure. Might need to reinforce the floor anchorage points. Sadly the 1969s Mini steel is not strong enough without extra support.
roger mcnab wrote: ↑Tue May 14, 2024 9:35 am is that a 5 speed gear knob and does it have a 5 speed box or is that just a teaser
The 22G1128 has just the regular four gears.
Coming back to the next step in seatbelt restauration.
The static belts were a great way to get to grips with the subject. However, it is also more challenging to completely overhaul automatic belts. To do this, of course, you have to look at the automatic mechanism in order to understand how it works and to be able to recognize and correct damage. The old Britax automatic rollers have an exciting technology. They have to be installed exactly horizontal in order to be unrolled. A solid steel ball lies in a very shallow bowl. If the ball is moved out of its lowest position, e.g. through acceleration, deceleration or an inclined position, it lifts a thin sheet metal plate which blocks a cogwheel on the outside. This immediately locks the belt. Only when the ball rolls back to the center and thus to the lowest point is the gear wheel released again.
