Starter motor.
36inter
Starter motor.
Post by 36inter »
Hello all, hope you can help. I have a high torque starter that when fitted the starter gear just rubs on the ring gear, I need to space it back couple of mm to cure this, does anyone make a proper spacer for this. Large flat washers will work for a short while but I'm sure the starter will flex causing problems, thanks in anticipation.
Pete
BAD942B
Re: Starter motor.
Post by BAD942B »
shorten the starter drive gear ?
Chris A
Polarsilver
Has thanked: 36 times
Been thanked: 51 times
Re: Starter motor.
Post by Polarsilver »
Make a Spacer .. obtain some sheet Alloy Material maybe from the likes of B&Q etc who sell various thickness & make a card template from a Weetabix Box & bolt onto the bell housing then use a ball end hammer & cut out card to the inner shape then reposition onto the starter motor & make the cardboard to the outer shape.. then shape the sheet alloy to suit your card template .. maybe several shims that will be needed to pack out & position the starter motor = job done.
I save sheet alloy,stainless & mild steel from whatever we scrap in the home such as old washing machines & toasters because that sheet material will come in very handy into my future projects .. only problem will be when i am Dead & NOK have to weight in my left over remaining scrap :lol:
36inter
Re: Starter motor.
Post by 36inter »
Thanks for the replies, I was looking for an easy fix :D .
BAD942B, the front faces of the starter gear are beveled, I guess to ease engagement with the ring gear, not sure how it would affect things if I machined it flat.
Polarsilver, I could fab up a plate, but I was being lazy and looking for an easy fix, there is a starter motor spacer for 1500 Triumphs but no idea if it would fit. I'll message the supplier and ask.
Appreciate the input from you both many thanks.
Pete
Has thanked: 131 times
Been thanked: 113 times
Re: Starter motor.
I'm entirely in the Polar-silver camp. With loads of off-cuts of pieces of alu and steel sheet, it'd take no more that half an hour to cut/snip out a couple of spacers. I'd say that this was an almost everyday maintenance task for your average mini owner.
CooperTune
Re: Starter motor.
Post by CooperTune »
I have a shelf just for converted Japanese Hi Torque starters. I have for years been matching correct starter ring gears and late pre engaged mini starters to solve starter issues. I freely give the Jap starters away with the understanding, they are worth what they pay and I'm not responsible. Steve (CTR)
iain1967s
Been thanked: 7 times
Re: Starter motor.
Post by iain1967s »
36inter
Re: Starter motor.
Post by 36inter »
I looked at Rimmer, I have no idea of its dimensions, I will ring them tomorrow, many thanks.
Pete
