Broken piston rings
KA2S4
Broken piston rings
Post by KA2S4 »
I have just pulled down a 970S motor, and found that the top ring on 3 of the pistons have broken into about 6 pieces.
What would have caused this?
Thanks for your help,
James
Re: Broken piston rings
Post by Tim »
A broken top ring can be caused by not removing the ridge at the top of the cylinder when re-ringing an worn engine.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
foggy
Post by foggy »
Hi James, some suggestions...
a)worn piston lands from years of revving, or overfueling washing any oil off.
b)Detonation, caused by shite fuel, too much compression, incorrect ignition timing.
c)Overheating the engine causing rings to end butt
d)incorrect gapping of rings causing rings to end butt
e)too much piston/bore clearance
Foggy
66S
Post by 66S »
Hi James,
The fact that it could have been broken when the piston was fitted shouldn't be overlooked either, although not so likely with three broken. Doesn't sound good :(
Regards
66S
Post by 66S »
foggy wrote:Hi James, some suggestions...
Foggy
Hi James,
Is it this engine?
http://www.youtube.com/watch?v=ykqi1CY5jY0
Austin Costin
Post by Austin Costin »
That will be the day you revved the tits off it so much it tried to empty the sump of oil :!:
Good video, who's car is that then :|
KA2S4
Post by KA2S4 »
Austincostin: Yes that was the day after you put about 8 litres of oil in the sump :shock:
66s: That youtube vid is on the day of the Okains Bay Cooper run, Me driving Pauls CCC rep with the 970s engine that i have now bought from Paul. How in the hell did you find that piece of incriminating evidence?
Gray
Post by Gray »
Did Paul make you ;) buy it afterwards then James?? Have you still got the nos 970 block?
KA2S4
Post by KA2S4 »
Gray: Yes i still have the NOS block, and a NOS crank, the crank in this one is 10/10, which is good, but it is out to +60.
Ok, so i'm just interested in why the rings broke, and how to stop it happening again,i guess i just need to use good fuel, make sure the timing is right, and cc the head before i use it. I don't have the head that was on this previously, so i'm prepping another. Should i also measure the piston ring groove, as it may be too wide?
Is detonation the same as "pinking"??
J
970s
Post by 970s »
James,
:cry:
Ridges + worn ring groove might be the reasons!
I had encountered +20 thou on a worn S pistons' top ring groove, :ugeek: machined them and fit thicker rings cure the problem! ;)
Wrong fuel hardly broke the rings, but the piston crown damage instead, hope your motor rebuilt going smooth!
Al :P
