Engine crankshaft 12G 1505A
Have engine block from Austin America with automatic transmission want to covert to manual transmission, can I use the crankshaft 12G1505A,thanks Richard
- Has thanked: 125 times
- Been thanked: 34 times
Re: Engine crankshaft 12G 1505A
Yeap, no problem. Same Crank as used in the Manual, though as I'm sure you're aware, the Primary Gear is different.
Thanks for reply would primary gear 22G1053 24 teeth work plus do you know if you can buy shim plate required between oil pump and engine block, appreciate any help thank you
As it's the same crank as in the manuals, that primary will fit no problem.
The only firm I know of who has the Oil Pump Spacer in stock is ReadSpeed in Brisbane, Australia. He doesn't have a web site, you need to ring them.
+ 7 3399 9999.
+ 7 3399 9999.
