Engine earth strap
richardACS
Has thanked: 41 times
Been thanked: 10 times
Engine earth strap
Post by richardACS »
Could anyone tell me where on the 'engine side' the engine earth strap is attached (I can see the fixed nut on the inner wing).
Thanks in advance...
360gts
Been thanked: 52 times
Re: Engine earth strap
Post by 360gts »
It is fixed to the clutch end cover...the first bolt under the starter . Make sure you have cleaned the paint off the area on the cover. Use a good bolt....also cleaned and a star washer under the strap. Can't emphasize enough how important it is to have a very clean area on both ends of the strap....including the wing.
Same applies to the area in the boot where the cable attaches to the body. Poor grounding is a menace...causes all sorts of issues.
richardACS
Thanks Dermot, presumably the thread on the bolt provides a clean earth route (with a new bolt and spring washer) and thread cleaned with a tap - surprised by it being the clutch cover - does it earth through the aluminium cover?
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Post by woodypup59 »
yes it earths well enough through the clutch cover. I add a bit of copper grease to all these connections.
richardACS
Many thanks both…
