My '65 SDL with wet suspension seems to have a slightly different front subframe to another wet front subframe I've come across.
Mine doesn't have the need for spacers that sit on the top of the towers (between subframe and cross member) but an otherwise identical appearing subframe (wet) does need them?
Looking through the factory parts manual it seems the spacers were a VIN dependent fitting, mine falls outside the range so aren't on my car.
Are the two subframes interchangeable? I can't imagine that the dimensions of the shell changed, more that the towers are different heights?
TIA
