5 bolt bumpers question
almondgreen
Post by almondgreen »
I have a question about 5 bolt bumpers.
How long have they been fitted to Minis ?
When was the change to 3 bolt ones.
Are all 5 bolt ones, original, or where 5 bolt reproduction ones made ?
Spitz
Re: 5 bolt bumpers question
Post by Spitz »
A friend's 64 Countryman I looked at yesterday has holes for the 5 stud bumper
Simon776
Post by Simon776 »
There were after market five mounting bumpers, but they use tags across the underside of the bumper so look quite different to a genuine one - at least on the underside.
Andrew1967
Post by Andrew1967 »
I've just picked up a couple of new 'old stock' repro 5 bolt bumpers - manufactured as Simon says.
Different profile (larger radius) than the originals by the looks of it.
cpr1
Post by cpr1 »
Andrew1967 wrote:I've just picked up a couple of new 'old stock' repro 5 bolt bumpers - manufactured as Simon says.
Had some like these, and they were a pig to fit. :x
Andrew1967
It'd certainly be a pig to fit on the back of the pick up :shock: .... :lol:
rogerotto66s
Post by rogerotto66s »
This seemed to be the “proper” topic to bring back to life!
I just purchased a set of 5-bolt bumpers (bottom in picture).
They do not have holes for corner bars.
Their profile is quite different when compared to my original 5-bolt bumper (1966 Austin Cooper S - top in picture).
- the corners are rounded with no sharp edges
- the bolts are mounted in a different manner
Can anyone provide info re: the timeline for the change in 5-bolt bumpers.
Roger Williams
Post by Old English White »
The bumper(s) you have purchased are the reproduction/aftermarket bumpers which Simon referred to in his post above. They are not an original fitment to any Mini.
rogerotto66s
Any conversion date for 5-bolt going to 3-bolt?
Any date range for the after-market bumper?
Roger Williams
360gts
Been thanked: 52 times
Post by 360gts »
rogerotto66s wrote: Thu Aug 31, 2023 11:25 pm Any conversion date for 5-bolt going to 3-bolt?
Must have been after MK2 production ended...I have had two MK2 S's
and they were fitted with the original 5 bolt bumper.
So, question is..were the 3 bolt bumpers ever fitted as standard or were they just replacements?????
Allen Brzeczek
Post by Allen Brzeczek »
I am of the considered opinion that the 3 bolt bumpers are an after market replacement. I fitted a stainless steel pair on my 67 S some 3 - 4 years ago which look OK but found that I had use rubber insertion on the front at it was prone to vibrating noisily especially on tick-over.
Have retained the originals for possible re-chroming at some later date.
MiNiKiN
Has thanked: 81 times
Been thanked: 31 times
Post by MiNiKiN »
rogerotto66s wrote: Wed Aug 30, 2023 11:44 pm This seemed to be the “proper” topic to bring back to life!
My original Innocenti bumpers look very similar with the same kind of bracket - so my best guess is that they are Innocenti
rogerotto66s
MiNiKiN wrote: Fri Sep 01, 2023 11:27 am My original Innocenti bumpers look very similar with the same kind of bracket - so my best guess is that they are Innocenti
Just found this on eBay.
It is described as an Innocenti bumper.
Roger Williams
MiNiKiN
Post by MiNiKiN »
rogerotto66s wrote: Fri Sep 01, 2023 5:03 pm
Behold, I told you so :D
Has thanked: 135 times
Been thanked: 113 times
I saw my first 3 bolt bumpers in the mid 70's when I was doing some work on my run-about 998 MSM130F and I am positive that they were Unipart, covered with that white stuck-on tape that was a bxxxxxd to get off. I feel that the 3 bolters were a means of cheapening production - by Leyland cans
