Oil expert required
DougR
Oil expert required
Post by DougR »
Hi folks, just running oil through the engine to check oil pressure etc., why is cheapo semi synthetic 5w40 denser than Duckhams 20w50? Surely it should be the other way around? Or are the components of the 20w50 separating? Any thoughts?
Doug.
Oneball
Has thanked: 10 times
Re: Oil expert required
Post by Oneball »
I don’t know how viscosity relates to density but looking at the pic I’d suggest the difference between the two is because the one is full of heavy carbon and metallic particles or there’s a temperature difference
Oneball
Post by Oneball »
Ps I hope you’re not thinking of putting that glass in the dishwasher ;)
Has thanked: 135 times
Been thanked: 113 times
Ah, it's a chemist you need to speak to. The first part is the WEIGHT of the oil and one of the oils weighs more than the other, hence sinks to the bottom while the lighter oil (by density - not colour) remains on the top.
If you shake the contents, they'll mix and not separate.
Yoi can get the same effect with silicon and normal brake fluids in a small jar. But they will ALWAYS separate because one will not absorb the other.
DougR
Post by DougR »
This makes interesting reading....
https://totalenergies-eng.prowly.com/15 ... to%20water
Basically the density is not proportional to the viscosity. It depends on lots of different things like chemical composition, additives, age, moisture content, temperature, and it's arbitrary and nobody cares about it and that's why it's not written on the tin.
Now let's see how good this dishwasher really is. :P
hanlminiman
Has thanked: 19 times
Been thanked: 33 times
Post by hanlminiman »
Way back in the 1960s we would call that a light & bitter in that glass served by the Phylis the "short" measure bar maid every time! :lol:
DougR
Post by DougR »
yeah over here it was known as a black and tan with the historical connotation - half Guinness half Ale, but it never got time to settle. :P. Must leave one sitting and see if they separate. ;).
Hipwell
Post by Hipwell »
The ‘weights’ of the oil is a measure of their resistance to flow at a set temperature.
