water pump pullry size
Dan Tweed grey
Post by Dan Tweed grey »
I've been running the larger size pulley for three years and although the engine runs normal tenp whilst moving , it gets hot when sat in traffic .
I fitted an aux fan to overcome this but i'm wonering if a smaller pulley wpould be the answer?
Dan Tweed grey
Re: water pump pullry size
Is that the plastic jobbie?
I have a four blade metal none at the moment.
Dan Tweed grey
Also I think the pulley is a later A+ big one , so spins slower.
BAD942B
Post by BAD942B »
Dan Tweed grey wrote: Sat Jun 10, 2023 12:58 pm Also I think the pulley is a later A+ big one , so spins slower.
double whammy, pump turns slower so moves less water & fan moves less air, 1/2 way step is to fit a high efficiency water pump from someone like KAD
Chris A
Has thanked: 135 times
Been thanked: 113 times
Or just run with waterless coolant. You ain't never going to boil it.....
Dan Tweed grey
I'm sure I have a small pulley in all my junk, better order a smaller belt first.
Fanfaniracing
Has thanked: 7 times
Been thanked: 20 times
Post by Fanfaniracing »
Dan Tweed grey wrote: Sat Jun 10, 2023 12:48 pm Is that the plastic jobbie?
I had a four blade Metal Fan like the Works Cars on my 8 port but always run hot. Had a large pulley wich slows waterflow to give the Radiator more time to cool the water down. Also have a 4 Core Radiator and Evo Waterpump fitted.
Now with only changing the Fan to a 11 Blade Fan 12G2129
all my overheating problems are gone. Even when pushing hard, the temperature didn't go over 95'C
Fanfaniracing
I always mix my colant with antifreeze and RO Water.
Something that also helps is that the Engine Block is very clean inside.
With a Rusty and dirty core you can use the best Radiator, Pump, Pulley, Fan Evans ect and will still have cooling issues...
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Post by Exminiman »
Fanfaniracing wrote: Sun Jun 11, 2023 9:50 am I always mix my colant with antifreeze and RO Water.
Out of interest, any reason why RO water rather then distilled water ?
Fanfaniracing
Whe have very hard water here and i think that if there's a possibility to avoid calcification in the engine you should do it...
BAD942B
Re: water pump pulley size
Post by BAD942B »
not sure where else you can buy RO water in the UK, but you can get it here https://www.envirogengroup.com/2021/10/ ... -water-uk/, luckily a lot of the area where we live & work has soft water
Chris A
Dan Tweed grey
Well this is the first time I've heard of RO water... I know some people use distilled or even rain water.
So I might just swap the fan for a modern plastic one. The water pump is high flow and the pulley is large A+ the rad is a Fletcher alloy one,
cheers all,,
Dan
Has thanked: 181 times
Been thanked: 64 times
Before tying one's self in knots looking for special waters, look in to you local town water supply. These days most cities and towns are fed from a Water Filtration System that have water quality outputs that way exceed any purity / hardness / Ph that come out of any bottling factory. It's in fact almost too pure for human consumption !
My old late mum, a retired GP used to tell us kids, if we ever mentioned bottled water, that if tap water was good enough for doctors and surgeons to wash and rinse their hand in, then it was good enough to drink!
Dan Tweed grey
Fitted small pulley and modern plastic fan.
All sorted no problems, tested on a very hot day / car show .
