Engine recipe..
- gs.davies
- Has thanked: 75 times
- Been thanked: 77 times
Engine recipe..
So, I’m most of the way through what is turning out to be a 2500 mile round trip.
I’ve used a load of oil and whilst the cars gone well, for the sort of things I want to do in it, I need more go. A lot more go.
If I was to build an engine capable of propelling a Mini at modern road speeds for hours on end, what would I need in terms of power, torque and specification? And by modern road speeds, I anticipate seeing some German motorways in the next twelve months.
Staying with the wand change, I think the 3.2:1 I’ve got is pretty good, but would consider taller.
- gs.davies
- Exminiman
- Has thanked: 58 times
- Been thanked: 56 times
Re: Engine recipe..
If you are looking for reliability, smoothness and decent MPG you could start of with a cam like a 256 profile, a single carb 1.5 SU and engine balanced.
Engine should be built with tolerances to suit long motorway miles in mind I would add some ZX1 after its been run in as well..
5 speed box would be ideal, depends on the engine you have or want, presumably they do helical gears in them still ?
From memory Dave Vizard gas a chapter about economy in the yellow book..might be worth looking it up
- gs.davies
Re: Engine recipe..
I’d love a five speed, but not sure how that could work with wand change.
Still want an 850 like appearance.
- Been thanked: 10 times
Re: Engine recipe..
If you want an 850 like appearance then it will have to be an 1100 based unit. But that is going to struggle to give the 70 - 80 bhp you would need to be looking at to give you your proposed requirements.
Personally, if it was me, I'd be thinking about a big bore unit.
- Andrew1967
Re: Engine recipe..
I’ve got a pretty standard (standard cam etc) 1330 S engine with a 3.1 diff S box and that pulls well and copes easily with 70 for long distances …
Go big bore … in my opinion a small bore engine can be made up to S power but it’ll be over stressed and never really be the same or better. Not that I know a huge amount about tuning but it makes sense really.
- Has thanked: 38 times
- Been thanked: 55 times
Re: Engine recipe..
Spend circa £4k on 5 speed box + £3k on re-con 1275 short engine + Head + Carbs + Cam etc .. add it up nothing is cheap these days.
- Has thanked: 19 times
- Been thanked: 9 times
Re: Engine recipe..
Go 1275. Swap the engine back when you’re done. Simpler, cheaper and easy changeover.
If not I’ve got a VTEC kit at mine Gary.
You can buy a tin of bronze green and brush paint it if you want the authentic look
Rolesyboy
Re: Engine recipe..
1098+ on a 4-synch magic wand 1128 gearbox with a 3.1 diff.
Keeps the look, will cruise at '70' all day long without much effort.
- gs.davies
Re: Engine recipe..
That’s pretty much what I have. It’s developed some issues on the run to IMM and back but where it really did struggle was some of the mountain passes. Whilst I couldn’t do Grand St Bernard as it was closed I did do the climb into Chamonix the other side and it was on its knees, grovelling up the hill, pulling strongly but 30 mph in third tops.
I’ve not ruled out big bore engines for this purpose and as I learn more about what I want from it, so the spec will grow.
- mab01uk
- Has thanked: 262 times
- Been thanked: 231 times
Re: Engine recipe..
For a lot more go with 5-speed gearbox at reasonable cost with reliability and modern road speeds for hours on end, plus seeing some German motorways in the next twelve months....sounds like one of the modern engine conversion for Minis with a suitable front subframe such as Allspeed is needed? https://www.allspeedengineering.com/ind ... -11-19-08_gs.davies wrote: ↑Mon May 29, 2023 11:25 pm So, I’m most of the way through what is turning out to be a 2500 mile round trip.
Engine Conversions on TMF:-
https://www.theminiforum.co.uk/forums/f ... nversions/
- gs.davies
Re: Engine recipe..
I’ve only just got over letting go of single leading shoe brakes, and whilst my purist tendencies are strong, this is beyond the pale (but completely true!)mab01uk wrote: ↑Tue May 30, 2023 8:05 pmFor a lot more go with 5-speed gearbox at reasonable cost with reliability and modern road speeds for hours on end, plus seeing some German motorways in the next twelve months....sounds like one of the modern engine conversion for Minis with a suitable front subframe such as Allspeed is needed? https://www.allspeedengineering.com/ind ... -11-19-08_gs.davies wrote: ↑Mon May 29, 2023 11:25 pm So, I’m most of the way through what is turning out to be a 2500 mile round trip.
- timmy201
- Been thanked: 42 times
Re: Engine recipe..
My 1100 cruises nicely at 100kph and doesn’t have problems going up hills. I don’t really get a chance to take it much faster as near me there isn’t many 110kph zones. I put in a 3.44 diff and I feel it’d definitely take a 3.1 with no problem
If I was planning on going on long trips more often I’d probably detune it a bit to cope with any fuel quality I come across
I think a pretty standard spec 1275 would be a much nicer option though if the budget allows
Re: Engine recipe..
My solution to current highway speeds in my classic mini. 1275 Cooper S block bored to 1360cc with SW 5 -07 mildly ported 940 MG Metro cyl head surfaced for 9.5 CR. Std 1.3 forged rockers. Cast LCB exhaust manifold with Maniflow down pipes and RC40 kit. Along with the Rover Cooper HIF44 and intake. What makes it all come together is my custom gear box. DAM 5626 with the ultra wide ratio gear set and two O/D drop gears and a 2.76 CWP. It will run 70 mph at 3000 RPM all day long. I have tasted 96 mph at 4000 RPM. I'm currently building the 5th gear box to this spec. I'm out of parts to do additional units. I have found even with roll up windows wind noise above 70 mph is very uncomfortable. With wide ratio gear set there is 1000 rpm step between gears. There is no good reason to shift to 4th gear below 50 mph. Steve (CTR)
Re: Engine recipe..
Q: What "Ultra Wide Ratio" gear sets are currently available?
Q2: What are "two O/D drop gears"?
- BAD942B
Re: Engine recipe..
thats not a big or wide rpm drop between gears, can't remember what the rpm drops on my SCCR 4 synch but at 7k change point it wasn't muchCooperTune wrote: ↑Wed May 31, 2023 1:56 pm With wide ratio gear set there is 1000 rpm step between gears.
Chris A
