145by 10 on 4.5J steel rims (1071 1964 Cooper S)
Hello
I have 165/70 by 10 fitted on my rose petal alloys.30psi on front
They also fit the original steel LP883 rims.
I was a bit surprised to feel the amount of effort to steer at very low speed and wonder
if 145 by 10 were fitted to the 1071 cooper S and might give less heavy steering.
Accepting that wheel geometry will play a part in this, would anyone be prepared to give me an overview or
direct my to a previous thread, or indeed correct any misconceptions that I may have.
(or a narrower rim)
Thank you
(or a narrower rim)
Thank you
- Been thanked: 3 times
Re: 145by 10 on 4.5J steel rims (1071 1964 Cooper S)
Don't forget that 145 x 10 radial and the 520 crossply tyre were the size the cars left the factory on. I will be running my 64 1275 S on 145 Bockleys
Hi David
Were the 145 by 10 radials fitted to 4.5J rims?
BR
BR
- Been thanked: 6 times
I have a 66/67 1275 S on the original factory fitted 4.5 steel rims with 165/70 x 10 tyres, front pressure 28 psi. I have an 11" steering wheel, when stationary yes, the steering could to a degree be described as somewhat heavy but so long as the car is in motion however slowly the steering is good. I have a tight turn off of the passage way into my garage and need to reverse and manoeuvre back and forth to get in/out but would not consider the steering as unduly heavy.
Just to mention some years ago I fitted the later Mk 2 rack which has a slightly different turn ratio but do not see this as necessarily an influencing factor.
Yes. 70 series tyres (165/70x10) just didn't exist for the first 6 or 7 years of 4.5" wheel useage...
Cheers, Ian
PS Caster has a lot to do with steering weight.... You will need adjustable tie rods to make a lot of difference but worn front bushes (or bent tie rods) can have some effect.
- timmy201
- Been thanked: 42 times
Have you got a standard size Mk1 steering wheel or something smaller?
I’ve got 165 tyres on mine & with the big 15.5” standard wheel the effort is noticeably less than a small 13” wheel
Thank you for all the replies.
I do have the standard steering wheel and will locate the Keith Calver article on suspension set up as a result of the heads up about castor angle.
Similarly the information on the 145 by 10 tyres being the original setup on the LP883 rims.
I may revert to the original size tyres.
Best regards.
Best regards.
- mab01uk
- Has thanked: 262 times
- Been thanked: 231 times
If all else fails....
Electric Power Steering Conversion Kit for Mini:-
https://www.holden.co.uk/p/electric-pow ... mini-spi-1
Thanks mabo1uk
Will work through all the obvious options
and as you say, if all else fails...
Have previously bought from Holden
Will contact them on Monday,
BR
panda911
BR
panda911
