Believe it or not Chris, I poured Nitromors onto my Cooper S Brocade trim as this too had been painted black. Results were awesome. Just keep an eye on it and use a soft small brash brush to agitate the paint. Wipe with a few damp cloths. Great way to clean the trim albeit a bit extreme in any othe rsetting! The nitromors doesn't seem to affect the vinyl. Worth testing a small patch first as obviously your seats are different but I would imagine fundamentally the same grade of vinyl. Good luck. It takes sodding hours.... Mark
Aerosol oven cleaner and a brass bristled brush works really well - will remove paint with no effect at all on the vinyl beneath. Also good on brocade - it doesn't dissolve the original gold detail on the vinyl.
Ant Hines wrote:Aerosol oven cleaner and a brass bristled brush works really well - will remove paint with no effect at all on the vinyl beneath. Also good on brocade - it doesn't dissolve the original gold detail on the vinyl.
Works great on Scalextric cars too (no wire brush thou)
