steering rack
rumba5278
steering rack
Post by rumba5278 »
ANY PHOTOS for a mk1 steering rack,,mine is hitting with the floor pan near the pinion hole,,no space for dust seal and floor pan is perfect,,my rack came from a mk1 aussy clubman and im using it on mk1 uk mini
Has thanked: 208 times
Been thanked: 80 times
Re: steering rack
They must be fitted up with spacer plates;-
rumba5278
Re: steering rack
Post by rumba5278 »
thanks my friend,,never saw that spacers in 30 years,,,,only aussy used that or all mk1s in general?
Re: steering rack
As best I know, only when an Aussie Rack is fitted up.
If the Rack is ever removed without removing the Subframe completely, they are a fiddle to get back in, so often, they are left out.
Item 26, and going off the P/N, it is a unique Aussie part
timmy201
Been thanked: 42 times
Re: steering rack
Post by timmy201 »
Hmm another thing to track down for my AYA6001 steering rack swap. I don’t suppose you’d have some spares Spider?
Re: steering rack
timmy201 wrote: Sun Apr 16, 2023 10:05 am Hmm another thing to track down for my AYA6001 steering rack swap. I don’t suppose you’d have some spares Spider?
I'll have a look how many I have, they are a bit thin on the ground as many cars I see no longer have them. If I don't have any, I think I have made a sketch.
Has thanked: 150 times
Been thanked: 137 times
Re: steering rack
I suspect that man of your obvious skill will easily be able to make a suitable spacer Tim
And while we're on the subject.......... Does the spacer shown by Spider replace the two spacers spot welded into the outside of the toe-board in the UK made body shells
Re: steering rack
I have to add a caveat to my earlier post.
The very early Aussie Racks had a shorter pinion and the housing was about 1/4 'shorter' where the Pinion goes in. These were around for less than a year. These didn't need those spacer plates.
Peter Laidler wrote: Sun Apr 16, 2023 11:27 am ,,,,and while we're on the subject.......... Does the spacer shown by Spider replace the two spacers spot welded into the outside of the toe-board in the UK made body shells
Pete, if you are referring to the Reinforcing strip about 5/8" wide that has the 2 holes in it where the U Bolt passes through inside the cab on the toe board, then no, it doesn't replace that. Our cars had that right to the end of production.
BAD942B
Re: steering rack
Post by BAD942B »
rumba5278 wrote: Sun Apr 16, 2023 6:25 am ANY PHOTOS for a mk1 steering rack,,mine is hitting with the floor pan near the pinion hole,,no space for dust seal and floor pan is perfect,,my rack came from a mk1 aussy clubman and im using it on mk1 uk mini
is that a 69 to 76 Clubman ? if it is its a Mk3 Mini in reality, if you are using the rack FROM anything later than a Mk2 Mini you will need to change the steering arms to Mk2 type as they are different from a Mk1, the Cooper S arms are alse beefier / stronger in both Mk1 & 2 for racing / rallying.
Chris A
Re: steering rack
I must have had my head screwed on yesterday - I remembered to look
PM me your address.
