Fuel tank thingy
SMOKE GREY
Been thanked: 10 times
Re: Fuel tank thingy
Post by SMOKE GREY »
SMOKE GREY wrote: Thu Jan 12, 2023 8:49 pm
Beatie wrote: Mon Jan 14, 2019 7:06 pm Here’s what’s the blanking plug looks like :D
It’s actually brass and came out quite well with an easy out .
The plug looks the proper job so obviously nothing to do with BMC :lol: :lol:
That’s a genuine plug , can’t remember the part number, got a bag of them somewhere.
21A352!
winabbey
Has thanked: 7 times
Been thanked: 15 times
Post by winabbey »
To summarise some of this discussion, the initial drain plug part 21A352 (as per Beatie's post) was replaced by the plug with tube - part 21A1401.
This image courtesy of Somerford Mini - https://www.somerfordmini.co.uk/catalog ... 774_100807
BMC Australia made its own equivalent of 21A1401 giving it part number AYA2150 for the threaded bit and AYA2149 for the assembly.
gs.davies
Has thanked: 75 times
Been thanked: 76 times
Post by gs.davies »
If ever there was an advert for the usefulness and the depth of knowledge available here, just see the post above.
Brilliant!
AndyPen
Has thanked: 18 times
Been thanked: 51 times
Post by AndyPen »
Really useful info, and just found this in the site's BMC bulletin - with dates ;-)
gs.davies
Post by gs.davies »
mk1 wrote: Fri Jan 11, 2019 9:40 am As far as I am concerned, those drain tubes are a total waste of time. The best thing to do is to glue the bleed screw in & cut it off flush.
Ok, Not a solution for the 10/10 conservator, but a great solution if you ever want to remove the tank again.
Right, finally got to the stage where I can fit the tank and the boot floor has the hole in the wrong place. Ho hum (M-Machine Mk1 Spec floor). What glue would folks recommend for this task? I've tried a calliper plug screw, that's too short to go all the way up to the taper and I suppose the nipple should be tight against that to seal it against leaks.
JB Weld followed by a 3/8 UNF grub screw. I have ones that have been like that for 30+ years & have never had any issues.
Lakeland997
Post by Lakeland997 »
winabbey wrote: Fri Jan 13, 2023 5:30 am To summarise some of this discussion, the initial drain plug part 21A352 (as per Beatie's post) was replaced by the plug with tube - part 21A1401.
I’m not sure that’s quite correct. The drain tube with pipe is pictured in the original Mini Cooper parts list and is labelled as 21A352
Confusing!
richardACS
Has thanked: 42 times
Post by richardACS »
I'm just getting to this issue at the moment, as mentioned by Andrew - it's there and would like to return same even though I can see they are a right pita. Dermott directed me to some for sale in Australia but their web site doesn't seem to be set up for selling abroad - pinged them an email but no response.
I'd like to know if the grommet is just a blank with a hole through or whether it is a thicker moulding that also acts as a supression rubber?
The slinger thingy however is still a hurtful point Andrew - my therapist has given up trying to get me through this :o :lol:
timmy201
Been thanked: 42 times
Post by timmy201 »
There’s a few places in Aus that sell them. If you want to order a few to make it worth the shipping and fees I’d be happy to receive them and post them on
https://bmiparts.com.au/product/drain-tube-fuel-tank
https://minisport.com.au/products/mini- ... be-spanner
winabbey
Post by winabbey »
I sent a small quantity of the NOS tubes to someone on here, but can't remember who.
AndyPen
Post by AndyPen »
winabbey wrote: Fri Apr 14, 2023 9:58 am I sent a small quantity of the NOS tubes to someone on here, but can't remember who.
I was me and yep, I think I still have a few (3 I think) as some who wanted them at the time didn't follow up once they'd arrived. Richard, pm me if you want any. The grommet I have was cleverly hand made by Dermot, but are now available at Somerford mini.
https://www.somerfordmini.co.uk/seal-ta ... loor-60-69
steve1071
Has thanked: 17 times
Been thanked: 16 times
Post by steve1071 »
I'd be up for buying one.... ;)
richardACS
timmy201 wrote: Fri Apr 14, 2023 9:57 am There’s a few places in Aus that sell them. If you want to order a few to make it worth the shipping and fees I’d be happy to receive them and post them on
Thats very kind of you - I would like 3 please...
richardACS
AndyPen wrote: Fri Apr 14, 2023 10:25 am
Andy I've been replying backwards to the posts and have said yes to Timmy - Timmy if you don't mind :oops: it would make sense for effort/postage if I were to get these from Andy - but again thank you!
360gts
Been thanked: 59 times
Post by 360gts »
I have a couple of NOS extra drain pipes left....if anyone is interested
Andrew1967
Post by Andrew1967 »
You sent some to me as well :)
AndyPen
Post by AndyPen »
I wont be back to my unit for just over a week folks, but will dig them out then.
Andrew1967
richardACS wrote: Fri Apr 14, 2023 9:33 am I'm just getting to this issue at the moment, as mentioned by Andrew - it's there and would like to return same even though I can see they are a right pita. Dermott directed me to some for sale in Australia but their web site doesn't seem to be set up for selling abroad - pinged them an email but no response.
Sorry for causing your problems Richard and hopefully your therapist will sort out your issues :lol:
The grommet sits on the boot floor, covering the hole and protruding through, rather than fitting like a conventional grommet.
I made a socket like this to fit and nip up the drain as it's almost impossible to get to with a spanner. I'll find a pic and post up, but here's a pic of the socket I made. .. cut a deep 7/16 1/4 "drive socket in half and then weld a bit in the middle !!
Andrew1967
How it should look … I hope !
richardACS
Super description and info - thanks...
