FJ Valves in a 295
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Re: FJ Valves in a 295
Post by woodypup59 »
Any chance of making that picture alot larger ?
5portsrock
Has thanked: 9 times
Post by 5portsrock »
I fitted fj valves in a 295 head on an offset 68mm bore and the exhaust opened but just brushed the bore so put a small pocket in.
wantafaster1
Has thanked: 16 times
Been thanked: 11 times
Post by wantafaster1 »
Was the trick not to use a 29mm exhaust valve as a 295 big inlet?
Pandora
Post by Pandora »
If you are going to have to pocket the block anyway, does it not make sense to then fit a 940 head (adjusted for CR)? or is there a specific wish to fit the small bore head?
CooperTune
Post by CooperTune »
I have been collecting 295 castings for years as 1275s become harder to find. My approach has been to have hard exhaust seats installed and I use the late multi groove O/S intake and exhaust offered from MSC. I have used a 940 casting and even added the extra studs as well as pocketing the block. I'm also using the late 998 press fit rods and flat top press fit pistons. Steve (CTR)
tweedy998
Post by tweedy998 »
I may be the guilty party here with my notions about FJ valves in the 295 head.
It all stems from my interest in the tuning of the small bore engine, which I do feel is often overlooked in the quest for more cubic inches. Many, many years ago, GRV created me a 295 head with 33mm inlet valves balanced up to larger than standard exhaust valves. At the time FJ valves were discussed but we decided not to go quite that large, possibly due to the potential complications of pocketing the block etc. However, I still have the urge to try and make one work with the REC FJ valve sizes.
1965 Tweed Grey Mk1 Morris Cooper 998
Toby
Has thanked: 12 times
Post by Toby »
I'll have to dig out my small bore 185 head with oversized valves. I never measured them but they sit very close
