Inline block in Mini…
Exminiman
Has thanked: 54 times
Been thanked: 51 times
Post by Exminiman »
Have a few large bore inline (MG Midget) blocks, which am thinking of using one to build up a mini engine.
I know inline are rarer than transverse, but I have it on the shelf and it is really well prepared already.
As far as I know the main difference is the end cap and the drilling / threading for the pickup pipe……
So caps and inline boring essentially.
Question is, am I missing anything ?
Dont have a bare large bore mini block to hand to compare, so would appreciate any comments.
Oneball
Has thanked: 10 times
Re: Inline block in Mini…
Post by Oneball »
Can’t you just machine the seal mount boss off the rear main cap and be good to go?
Fanfaniracing
Has thanked: 7 times
Been thanked: 20 times
Post by Fanfaniracing »
What about the Half Moon Seal when machinig it down this way?
Has thanked: 181 times
Been thanked: 64 times
You might have to do some work around the Oil Pick Up on the sump rail to get it to seal to the O Ring on the gearbox.
I might be talking out of my hat here, however, given these are much thinner on the ground than a transverse, surely you could find someone to do a swap with ?
Oneball
Post by Oneball »
Fanfaniracing wrote: Thu Mar 30, 2023 8:36 am What about the Half Moon Seal when machinig it down this way?
Half moon is on the front main cap.
Fanfaniracing
Oneball wrote: Thu Mar 30, 2023 8:57 am
You're absolutely right of course
360gts
Been thanked: 52 times
Post by 360gts »
I have used these blocks on numerous projects. All you need is an angle grinder...cut off the surplus strip on the end cap......
The oil hole requires no modifications.
Here is a picture of the front cap and the end cap that has had the excess piece removed.
You now have a really good transverse block.
Exminiman
Post by Exminiman »
Thanks for the responses, much appreciated.
Have to say hadn,’t thought of just grinding off the old scroll seal :D
Annoyingly this block even has a an MED, lip seal kit on that end.
Dermot, did you have any issues with the pick up pipe thread ?
Will get out in the workshop this weekend and have a real look father than trying to plan things remotley from the sofa :lol:
OzOAP
Been thanked: 9 times
Post by OzOAP »
Let me know if you are not needing the lip seal kit.
I'm just about to start an in-line engine build
360gts
Post by 360gts »
Exminiman wrote: Fri Mar 31, 2023 7:16 am Thanks for the responses, much appreciated.
Absolutely no problems....even my vintage race engine is one of these in-line blocks.....ran all last season without a glitch.
The seal is larger than the threaded hole in the block.
We don't have a large source of the transverse blocks over here....they only came in the America 1300....we did have lots of Midgets etc....so good supply of in-line blocks here.
CooperTune
Post by CooperTune »
Not that you don't have enough information, I have been using Spridget blocks for 20 + years. The first time I milled the excess from the rear cap and bored the threaded pickup tube hole. I machined a sleeve and pressed it in place to reduce dia. of bore. The second and following ones I found it not required. Inline 1275 units are getting harder to find these days. I have a collection of A and A+ blocks used at 73.5. I had planned sleeving them for reuse. The current turn around time and price increase has me wondering it will be worth while? Steve (CTR)
Exminiman
Post by Exminiman »
OzOAP wrote: Fri Mar 31, 2023 11:19 am Let me know if you are not needing the lip seal kit.
PM your address and will pop in the post, just cover the postage.
Should be perfect as block has never had a crank fitted…….
Exminiman
Post by Exminiman »
Thanks for the opinions, much appreciated, helped me clarify I wasn’t missing anything.
I would never get the money back on all the machining and prep’, so will build it up for a Mini.
Anyone want a Factory, EN 40B 1275 Midget crank, re nitrided , actually I have two! :lol:
