Floating nut things in the floor
Exminiman
Has thanked: 58 times
Been thanked: 57 times
Post by Exminiman »
Been searching for ages, but cant remember what they are called...can some one help please ?
I believe someone makes those floating nuts things that the factory used for some assembly reason.
Any idea please ?
Andrew1967
Re: Floating nut things in the floor
Post by Andrew1967 »
Caged nuts ;)
Pretty sure Mini Machine do them .
Has thanked: 262 times
Been thanked: 231 times
Exminiman wrote: Thu Mar 02, 2023 4:59 pm Been searching for ages, but cant remember what they are called...can some one help please ?
Any idea please ?
Floating caged nuts are used in mechanical production to allow for wider tolerances when assembling two components while lining up threaded fasteners. If the nuts were welded or riveted in position the alignment would need to have a smaller tolerance and manufacturing components to tighter tolerances increases their cost.
Exminiman
Post by Exminiman »
Thanks folks, will give MM a call, I had in my mind they had a specific name, but maybe not.
MiNiKiN
Has thanked: 95 times
Been thanked: 31 times
Post by MiNiKiN »
They are also called 'captive nuts'
