Does anybody know if it has connections for sidelights?
Want order some new headlights with sidelights, I installed this loom 17 years ago and I can’t remember. http://www.minispares.com/product/Class ... o%20search
Hiya Terry, all looms should have a connection for sidelights, it’ll be a red wire that terminates near the front right hand wing along with the blue/red and blue/white wires for the dip and main beams.
Stopped-again wrote: ↑Sat Feb 18, 2023 10:25 pm
Excellent!
Should make life easier, didn’t want to go pulling that loom out under the slam panel before ordering. Thanks!
So I dug into this a bit today, and all I can find are these two white/black wires that I can’t identify.
That’s the ignition circuit wiring I think. The white wire is the 12v ignition switch feed to the coil and the right black/white wire goes to the other terminal of the coil. The left black/white connects to the points fly-lead from the distributor.
The bundle of lighting wires you’re looking for are tucked up under the slam panel, usually pretty close to the bonnet release or vertical support.
iain1967s wrote: ↑Sun Apr 02, 2023 10:27 pm
Thanks! I dug a little further and found a single red wire that comes on with the park lights. It was buried in the bundle of lighting wires.
