Pot joints
- Been thanked: 29 times
Pot joints
Does anyone have any experience of using pot joints in a remote 1128 box at all . I’ve been using the MED hardy spicer converters with pot joint output shafts . Works well no problems but there out of stock at the moment . So I was just wondering if anyone is using pot joints. Benefits, there readily available, and not to expensive. How would they compare to say Quinton hazel / rubber crosses / S hardy spicer set up in strength reliability in a 100 bhp fast road engine . Opinions appreciated… Shirley
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- timmy201
- Been thanked: 38 times
Re: Pot joints
I use pot joints on my 1128 gearbox. They’re much better than rubber cross & QL5000 type uni joints.
I don’t know how they compare for outright strength compared to a hardy spicer, but they will inherently be smoother due to the constant velocity design
Re: Pot joints
I would agree... replaced the output shafts, side covers and drive shafts on my S gearbox. I used second hand bits that have lasted without any issues for many years.
Cheers, Ian
Cheers, Ian
Re: Pot joints
Thanks for reply’s so far . Another question to add . If using pot joints could I use a maniflow LCB or freeflow with no issues on clearance…. Shirley
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
- gs.davies
- Has thanked: 70 times
- Been thanked: 66 times
Re: Pot joints
I've converted to pot joints - I have an 846 box and I've dry fitted the Maniflow Freeflow manifold and seems to clear.
Re: Pot joints
I've got 1128 boxes & pot joints in two of my cars. One has a Freeflow and the other has had both a Metro cast iron LCB and an MPi LCB fitted with no problems.
If you're feeling flash, you can also use the Hardy Spicer converters on a pot joint diff.
Re: Pot joints
After a phone call to Minispares they informed me that they have the MED hardy spicer converters to pot joint outputs in stock . So had a trip down to Minispares. Taken on board the info and may well try pot joints in the future … thanks Shirley
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
- Been thanked: 9 times
Re: Pot joints
Rich & I have both used Pot joints in an 1128 box. Much better than any of the other alternatives really.
- W1NG3D
Re: Pot joints
Another voice in favour of pot joints here! They work well with my current setup which, on paper, should be pushing out around 100hp at the flywheel.
- Been thanked: 15 times
Re: Pot joints
Used them on the rally car with that box, never had a problem with them and they clear the exhuast. Primarily cos I couldn't afford the hardy splicer setup
Re: Pot joints
I too use pots on my mk1 remote, I used all second hand parts to save money. There are however two different sizes to be aware of.
- Has thanked: 38 times
- Been thanked: 14 times
Re: Pot joints
I discovered this when fitting a complete post '84 driveshaft and disc set up to a '74 rod change box. The later pot joint diff input diameter was larger. I'd already transplanted the '74 unit into the car and was planning on simply sliding in the whole driveshaft/pot joint assemblies in afterwards. No go.Dan Tweed grey wrote: ↑Fri Feb 10, 2023 3:54 pm I too use pots on my mk1 remote, I used all second hand parts to save money. There are however two different sizes to be aware of.
Choice was to change the diff output covers or swap the pot joints on the shafts so I went for the latter.
