Any Old Iron!
Been thanked: 10 times
Re: Any Old Iron!
Sort of raises the question, about the MS block and what date code would it have.
Probably not practical, but would be good if you could choose date code you wanted :o
That ain't going to happen, is it. How could you order a date coded block when the numbers are cast into it, it would mean them being cast to order. .
Exminiman
Has thanked: 58 times
Been thanked: 57 times
Re: Any Old Iron!
Post by Exminiman »
mk1 wrote: Fri Feb 03, 2023 8:08 am
That ain't going to happen, is it. How could you order a date coded block when the numbers are cast into it, it would mean them being cast to order. As with all stuff like this 90+ % will be going to Racers who don't give a stuff about things like this.
Guessed as much, Just thought would be icing on the cake.....cant be beyond the wit of man....
Re: Any Old Iron!
The only way that anyone can get costs down on a project like this is by casting a large number of blocks in one go & machining them in the same way. Invariably there is as much cost in setting up as there is in machining time. Doing a large number together amortises the set up cost over a large number of items. Doing them individually would push the price up exponentially. I doubt that anyone would want to swallow the cost of a date coded block, even if someone was prepared to do them.
Costafortune
Has thanked: 36 times
Been thanked: 38 times
Re: Any Old Iron!
Post by Costafortune »
Imagine talking about date coded blocks 40 or 50 years ago. :lol:
Re: Any Old Iron!
Costafortune wrote: Fri Feb 03, 2023 3:54 pm Imagine talking about date coded blocks 40 or 50 years ago. :lol:
Indeed :lol: :lol:
mk1coopers
Re: Any Old Iron!
Post by mk1coopers »
Just 3D print a date code, stick it to the block, paint over it ?
251 ENG
Re: Any Old Iron!
Post by 251 ENG »
Historic race cars haven't had to use cooper s blocks for years .
I think they would be very limited demand for new blocks for appendix K 1293 race engines
Formula Juniors have to use blocks with tappet chest covers but technically they should be AEG 151 thin flange ones
bubbacluby
Re: Any Old Iron!
Post by bubbacluby »
Exminiman wrote: Fri Feb 03, 2023 7:45 am Sort of raises the question, about the MS block and what date code would it have.
What are Minispares up to with their recast a-series blocks?
I haven't seen or heard anything about them since IMM60?
Exminiman
Re: Any Old Iron!
Post by Exminiman »
Phoned them up last week to ask the question, transferred to someone “ who would know”.was told maybe by end of this year, more likely early next….still some testing to do though. If anyone knows any more please do chime in
Exminiman
Re: Any Old Iron!
Post by Exminiman »
mk1coopers wrote: Fri Feb 03, 2023 5:37 pm Just 3D print a date code, stick it to the block, paint over it ?
Thats all I could think of, maybe in aluminium……..possible factory option or kit, for those who need it or want it….
Had my tongue firmly in my cheek when I suggested it though ……
Re: Any Old Iron!
Ha, ha, Poor old Minispares, if they bring a new product out & an issue is found they are condemned for being slap dash, invest thousands on something like a new S block & make sure it is tested THOROUGHLY & they get it in the neck for taking too long. Makes you wonder why they bother doesn't it :lol:
I have seen the latest "final" version of the cast iron block & although they don't have a selectable date code module fitted, they look superb. They need testing before they will be released but I bet they will be on the shelf within the next 12 months. I'm sure they will be worth the wait.
Exminiman
Re: Any Old Iron!
Post by Exminiman »
I thought by the end of next year was good........just glad someone is producing them :D
Big fail though on the "selectable date code module fitted" front ;)
