1275s LCB recommendation
ateichert
Post by ateichert »
Can anybody recommend a LCB for a stock 69-71 1275s engine. There seems to be a lot of choices.
Thanks Mike
iain1967s
Been thanked: 7 times
Re: 1275s LCB recommendation
Post by iain1967s »
I took the LCB off my 1275 S and fitted a Maniflow freeflow, with L71 adaptor to join up to the front pipe
http://www.minispares.com/product/Classic/C-STR816.aspx
http://www.minispares.com/product/Classic/L71.aspx
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Ensure your new LCB is suitable for what type of Drive Shaft Coupling you are using to make sure there is sufficient clearance between the components.
Then when fitting make sure that LCB center pipe Flange to the Cyl;head there is some clearance so LCB central flange will not touch the underside of the inlet manifold when it is all bolted up ;)
Roadrunner
Post by Roadrunner »
I used a Maniflow LCB with a maniflow exhaust on my last mini though I did have a couple from Special Tuning in Abingdon years ago A three branch which was not a good buy and an LCB which as far as I could see is what Maniflow make now
Has thanked: 181 times
Been thanked: 64 times
Perrys - better than Maniflow and much easier to fit.
MiNiKiN
Has thanked: 83 times
Been thanked: 31 times
Post by MiNiKiN »
Spider wrote: Sat Nov 19, 2022 5:11 pm Perrys - better than Maniflow and much easier to fit.
Never heard of them. Any Link available?
MiNiKiN wrote: Thu Nov 24, 2022 9:39 am
Sadly, they don't do themselves any favours by not having an on-line listing, but this is one type here;-
https://mgspareparts.com.au/collections ... y-included
MiNiKiN
Post by MiNiKiN »
Seems reasonably priced too, if I factor out customs and shipping
MiNiKiN wrote: Fri Nov 25, 2022 1:11 pm Seems reasonably priced too, if I factor out customs and shipping
I do like them. I think I can buy Maniflows locally cheaper than these, but I'm happy to pay that bit extra for the Perrys.
