If you have a front mounted rad` it seems like a no brainer, air will be forced through the rad` and the electric fan will come on when extra cooling is required.
However, with a side mounted rad`, does it really get much natural airflow ? surly lots of the air goes into the engine bay and is pulled out under the car without needing to go through the rad ?
So.......is it better to keep the engine powered fan on a mini with side mounted rad, and be sure that you are getting some airflow through rad at all times..?
EDIT or maybe keep the electric fan on at all times might be another theoretical solution...
Or am I just plain wrong and overthinking it...
