Disk brakes with standard drums at the back
btetley
Post by btetley »
I'm putting 8.4" discs on the front but planning to keep standard drums at the back. Has anyone done this. How does it feel when driving? . My
reason for doing this is because the group2 arches I have wont keep the tires under the flare at the back if i use a spacered drum. The front arches are wider than the rear and accomodate the increased track width. The arches came as a set.
minibitz
Been thanked: 13 times
Re: Disk brakes with standard drums at the back
Post by minibitz »
Aside from the additional built in spacer on Cooper/GT drums they are otherwise the same internally as regular drums so will give exactly the same level of braking,
Has thanked: 237 times
Been thanked: 208 times
How about using standard rear drums but with separate thinner solid alloy spacers to exactly suit your rear arches/wheel offset therefore reducing the front to rear stagger to a minimum?
Minispares spacers:-
http://www.minispares.com/shop/classic/ ... spx?200104
Alex
Post by Alex »
The disc setup is wider than the drum setup, I found the handling was distinctly different and odd until I widened the rear track too.
btetley
Post by btetley »
mab01uk wrote: Mon May 23, 2022 8:18 am How about using standard rear drums but with separate thinner solid alloy spacers to exactly suit your rear arches/wheel offset therefore reducing the front to rear stagger to a minimum?
Unfortunately using thin spacers adds an extra layer of compliance during certifibation and those spacers wont comply as is.
btetley
Post by btetley »
Alex wrote: Mon May 23, 2022 11:34 am The disc setup is wider than the drum setup, I found the handling was distinctly different and odd until I widened the rear track too.
Im quite annoyed that the rear arches atent as wide as the front. I might have to add fiberglass to widen them.
minibitz
Post by minibitz »
btetley wrote: Wed May 25, 2022 12:11 am
Are you in New Zealand by any chance? Sounds like the dumb rules applied here.
Most brands of arch are narrower at the rear so nothing unusual there.
How about getting cooper drums and then machining the outer spacer portion down to the appropriate width for your needs?
Another possible solution for using the correct spacered rear drums is to buy a set of Group 5 arches which are the same style as Group 2 but wider and then just use the wider rear arches from the set along with your existing Group 2 front arches.
Minispares - WORKS GP5 WHEEL ARCH SET PREMIUM QUALITY:-
http://www.minispares.com/product/Class ... |Back%20to
Minispares - WHEEL ARCH SET GROUP 2 PREMIUM BLACK:-
Has thanked: 137 times
Been thanked: 116 times
This is just another example of not knowing where the questioner lives, making answering the question impossible...... Where are you based Btetley?
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
Also to consider when changing to front disc set ups from oe front shoe brakes there is a need to look at what size rear brake cylinders are in use .. as the rear subframe mounted Brake Bias Valve & the Master Cylinder to be used will need to be evaluated.
Just remember that Rear Brakes must NOT Lock up ;)
gs.davies
Has thanked: 72 times
Been thanked: 68 times
Post by gs.davies »
Wouldn’t it be a bit tail happy with such an exaggerated difference between front and rear track?
AndyB72
Post by AndyB72 »
gs.davies wrote: Thu May 26, 2022 8:05 pm Wouldn’t it be a bit tail happy with such an exaggerated difference between front and rear track?
I'd be interested to know this too as I'm considering using S discs on the front of my GTM with non spacer drums on the rear to help with clearance issues.
I thought about this while day dreaming on my drive back from Carlisle yesterday. Ignoring the braking issues, while the front and rear track is well thought out mathematically, I'm not too sure that the 1.5" (?) we're talking about here will make any real difference for a normal road car/vehicle. Chuck it about on the corners and it might get a bit skittish as they say. It's almost a convention for the F and R to be the same...... ALMOST!
You'll see no end of lorries with a narrower rear track than the front. Skinnier tyres, small dia tyres, front wheels on dual axles narrower track etc etc. It's not as if you'll be putting a set of radials on the front and cross-plies on the rear
