Hi,
I’m trying to get my 64 Cooper ready for the L-B run on the 15th following a complete rebuild. Having problems with the clutch. It has been into my local garage 3 times to try and fix it but still having problems. After a very short while of driving it engaging a gear is causing the cogs to grate. Garage says they have check air in the system and can’t see any other obvious issues. Any other suggestions please.
998cc A series - clutch problems
- Has thanked: 10 times
Re: 998cc A series - clutch problems
If you’ve adjusted it correctly and there’s no air in it, there’s probably wear in the clutch arm ball and socket and/or the pedal/master cylinder clevis
