Pcv valve operation
Daz1968
Pcv valve operation
Post by Daz1968 »
Can anyone explain how the pcv valve works, I have noticed on my cooper that if I disconnect hose from tappet cover the engine stalls so I presume it is constantly drawing air from the block, is this the correct operation, it just seems strange that it draws so much air, I would have thought when idling the vacuum would close the valve and seal it,
Ronnie
Has thanked: 12 times
Been thanked: 30 times
Re: Pcv valve operation
Post by Ronnie »
Daz1968 wrote: Sun Apr 10, 2022 6:59 pm Can anyone explain how the pcv valve works, I have noticed on my cooper that if I disconnect hose from tappet cover the engine stalls so I presume it is constantly drawing air from the block, is this the correct operation, it just seems strange that it draws so much air, I would have thought when idling the vacuum would close the valve and seal it,
Hi ;) check this link out. > https://www.mgaguru.com/mgtech/engine/cv103.htm
seandoyle
Post by seandoyle »
Thanks for posting that,very informative.
Daz1968
Post by Daz1968 »
Thanks for that, I now understand how it works and have established my inconsistent tickover was actually caused by a leak on the oil filler cap, now that is fixed it works fine,
It appears it always pulls a vacuum in crank case to prevent oil leaks and fumes, I think when I remove the hose it gives too big an air leak in the system causing it to cut out.
Hopefully all will be ok now,
Has thanked: 138 times
Been thanked: 116 times
Interesting..... The article states that the top cover has a small hole in it. I've searched in my top cover and there isn't one. I can't think of any reason for NOT having one and understand the reason why there should be one.
What size is the hole?
Oneball
Has thanked: 10 times
Post by Oneball »
Daz1968 wrote: Mon Apr 18, 2022 10:21 am Thanks for that, I now understand how it works and have established my inconsistent tickover was actually caused by a leak on the oil filler cap, now that is fixed it works fine,
There’s something wrong with your PCV, it shouldn’t cut out, you’re either missing a spring, check valve or the diaphragm is holed.
Easy test is when you remove the oil filler cap the suction should be enough to depress a rubber glove over the filler neck but not suck it in.
Daz1968
Post by Daz1968 »
I also stripped the Pcv valve down, checked the internals and made sure all was free, so maybe that in combination with the leak on oil filler cap has solved it, but the phrase if it ain’t broke don’t fix it will apply for now,
The hole in the top plate is very small I don’t have anything to measure it but about 1mm I would guess
Ronnie
Post by Ronnie »
Peter Laidler wrote: Tue Apr 19, 2022 5:51 pm Interesting..... The article states that the top cover has a small hole in it. I've searched in my top cover and there isn't one. I can't think of any reason for NOT having one and understand the reason why there should be one.
Both types have them, also Peter they have a FV No :?:
Cammsjb
Post by Cammsjb »
PCV plate with hole on my June 69 MK2 S.
