Has anyone come up with a suitable fuel tank neck grommet for internal tank?
Thanks Mike
61 countryman fuel tank grommet
- Has thanked: 4 times
- Been thanked: 22 times
Re: 61 countryman fuel tank grommet
I'd try Triumph Herald or Vitesse.. They use the same cap, and they have a tank with a protruding neck, so the neck diameter must be the same.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
- woodypup59
- Has thanked: 8 times
The same size cap apparently fits A30, and A35, but I'm not sure if sedan and countryman are the same. It will also fit a several of the smaller Triumphs and Standards from the '50s and '60s. Any of them chould be a candidate for the grommet.
This ebay seller lists two sizes for A30/35, with dimensions, but I think they are both too big. From memory the neck has an OD of 2 inches (~51mm).
Austin A30 A35 Fuel Petrol Tank Filler Neck Grommet Rear Panel Rubber Small Type
Classic Austin A30 A35 Fuel Petrol Tank Filler Neck Grommet Rear Panel Rubber
1955 BSA C11G
1969 Triumph TR6R
1955 BSA C11G
1969 Triumph TR6R
- Andrew1967
Anyone able to post up a picture of an original grommet for reference ?
I have a couple in the shed somewhere that I’ve never been able to ID that came from a BMC garage.
Sorry, only in the car. Probably of limited value.
I was wrong, the OD of the neck is 1 3/4" (about 45mm). Its even smaller than I realised. The flange on the outer part of the rubber grommet measures about 67mm, maybe 2 5/8. I can't measure the hole in the panel.
Oh and ignore the wood in my photo, its probably a bit of gum tree or something.
1955 BSA C11G
1969 Triumph TR6R
1955 BSA C11G
1969 Triumph TR6R
