So there you are your budget spent, every conceivable surface coated with magic engine building paste in with the engine out with the spark plugs and crank it over safe in the knowledge the paste is as used by the most legendary engine builders, hoping oil pressure arrives in under 20, 40 60 seconds or If you are a tight Yorkshire man you rummage around the scrap bin throw this together connect to each oil cooler pipe in turn stick the suction end in 5 litres of Minispares best pump until you feel resistance...
I know its messy but what price almost instant oil pressure.....
Starting A newly rebuilt engine
- Been thanked: 7 times
