Standard rad mount to S Spec
Dr S
Post by Dr S »
Hmm. Supercharger pulley in the way. Guess I need to be S spec to clear it. Is it a job that can be fabbed up at home ? Or is it just order the bits and get on with it? Back in the day would an s spec shroud have been an easy find? Or is a home brew job more in keeping?
1071bob
Been thanked: 52 times
Re: Standard rad mount to S Spec
Post by 1071bob »
If your lower shroud is ok you can covert it to S spec by changing the lower bracket. You'll need to find a 'double bend' connecting bracket to suit or you can bend the standard one to suit.
I have a couple of the shroud brackets but no connecting bracket.
Daz1968
Post by Daz1968 »
I modified mine with one of these brackets, then bent my standard lower mount bracket as per pic above and worked fine, much easier than sourcing correct parts.
Has thanked: 138 times
Been thanked: 116 times
Where do you get this new S type lower shroud part? Or have I got to fabricate one?
Dr S
Post by Dr S »
I’ve taken the lazy option and just ordered it all up from minispares. 7ent seem to sell the weld on bracket.
1071bob
Post by 1071bob »
The 7ent USA ones are from me ;)
