Headlining frames
- Has thanked: 19 times
Headlining frames
Is the front half of a Mini van headlining frame the same as a saloon ie are they interchangeable? Thanks
Rolesyboy
Re: Headlining frames
The van ones small tags on to screw through, not same as estate or pickup as different again
- Been thanked: 53 times
I'm sure I used a front section from a traveller (Years ago)...can't remember if I had to shorten it or not. I do know you can use these in the pickups.
