Positive earth
whistler
Has thanked: 18 times
Positive earth
Post by whistler »
Just about to start reassembling my 66 SDL and need to decide if I'm going to stick with positive earth or switch to negative earth. I'm keeping the dynamo and voltage regulator.
Need some input on pro's and con's?
Can't remember if the fuel and temp gauges are polarity conscious or not.
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Re: Positive earth
Post by woodypup59 »
Fuel and temp gauges - if original - are not polarity sensitive.
Radios, tachos and the newer (electroic) type of voltage stabilser for the gauges are likely to be polarity sensitive.
Has thanked: 138 times
Been thanked: 116 times
Re: Positive earth
I would say that the only reason to keep it +ve earth is if you want to keep the old 1966 radio.( - or to satisfy the originality fiends). If not, change to -ve. Thinking on my feet, 1966 mini is simplicity itself. As Woody says, voltage stab and gauges are OK. Done it a few times. Ammeter wires will need reversing.
whistler
Re: Positive earth
Post by whistler »
Peter Laidler wrote: Wed Oct 06, 2021 2:01 pm I would say that the only reason to keep it +ve earth is if you want to keep the old 1966 radio.( - or to satisfy the originality fiends). If not, change to -ve. Thinking on my feet, 1966 mini is simplicity itself. As Woody says, voltage stab and gauges are OK. Done it a few times. Ammeter wires will need reversing.
Thanks Peter.
whistler
Re: Positive earth
Post by whistler »
woodypup59 wrote: Wed Oct 06, 2021 1:43 pm Fuel and temp gauges - if original - are not polarity sensitive.
Thanks.
Been thanked: 10 times
Re: Positive earth
I would ask why?
If you have a REASON to change from Pos to Neg then maybe it makes sense, if not then why bother?
Re: Positive earth
I would only change to -ve if I was upgrading to an alternator. As Mark says why bother otherwise.
whistler
Re: Positive earth
Post by whistler »
I may upgrade to an alternator in the future and it's easier to install a negative earth radio than to make an insulated box if it stays as positive earth.
AndyPen
Been thanked: 50 times
Re: Positive earth
Post by AndyPen »
My old rev counter was positive earth - so may set our 1071 up that way. Our SDL 970 is negative earth these days.
Andrew1967
Re: Positive earth
Post by Andrew1967 »
mk1 wrote: Wed Oct 06, 2021 3:52 pm I would ask why?
I converted my Mk2 998 Cooper to Negative earth years ago .. no idea why and haven’t bothered since on other projects, as no real reason to do so.
Dearg1275
Re: Positive earth
Post by Dearg1275 »
If you want to charge your mobile phone on the move safely negative earth is the way to go. If you are happy to walk to the next phone box positive earth will get the job done. 😉
snoopy64
Has thanked: 84 times
Been thanked: 14 times
Re: Positive earth
Post by snoopy64 »
I left my mk2 positive, I just bought a pos earth radio there’s plenty around
Kevin
gs.davies
Has thanked: 72 times
Been thanked: 69 times
Re: Positive earth
Post by gs.davies »
Dearg1275 wrote: Wed Oct 06, 2021 9:35 pm If you want to charge your mobile phone on the move safely negative earth is the way to go. If you are happy to walk to the next phone box positive earth will get the job done. 😉
I never really did get to the bottom of this - if a phone charger is plugged into a cigarette lighter socket which is wired and insulated so that it behaves as if it's positive earth, what will happen to a phone plugged in if it comes into contact with the car's metal work..?
Re: Positive earth
gs.davies wrote: Thu Oct 07, 2021 2:14 pm
Nothing. A mobile phone is not a car. All cases on mobile phones are insulated from the works inside. The biggest issue with doing what you describe is an accidental short between the charging socket & the car's body which could be quite an issue unless it is correctly fused.
