Fuel Tank Surface Rust
rogerotto66s
Re: Fuel Tank Surface Rust
Post by rogerotto66s »
rogerotto66s wrote: Sun Aug 22, 2021 3:17 pm
My plan for Monday / Tuesday is :
- pour out vinegar
- rinse with baking soda and distilled water (several times) to neutralize the acid
- rinse with acetone to remove remaining water
- unplug holes
- dry with hair dryer and shop vac (blowing air in)
- coat inside with 2 stroke oil
I will provide an update in a few days.
Here are a few pictures of the final LH tank.
Roger Williams
rogerotto66s
Here are pictures of my RH tank.
I had previously cleaned with vinegar, neutralized with water & baking soda, rinsed and air dried.
It was OK but I thought it could be better.
So....
- plugged holes (gas & vent)
- used 50/50 mix of Muriatic acid / distilled water and sloshed around (3 cups each)
- rinsed with distilled water & baking soda (several times) to neutralize the acid
- rinsed with Acetone to remove remaining water
- unplugged holes (gas & vent outlet)
- dried with shop vac (blowing air in)
- coated inside with 2 stroke oil
Ready to install LH & RH tanks in boot.
I found another topic showing proper install of vent pipes from tanks through boot floor.
Roger Williams
InnoCooperExport
Has thanked: 4 times
Been thanked: 9 times
Post by InnoCooperExport »
timmy201 wrote: Mon Aug 23, 2021 11:54 pm I haven’t seen any plastic tanks out here for years. The guy who was making them sold the production gear and the subsequent owner hasn’t made any yet
Just a thought, but wouldn't it be very easy to make a plastic tank out of two halves that are then epoxied together? I don't know which type of plastic would be suitable but I would imagine something like ABS which is also vacuum-formable would make it a doddle to make.
edit. a quick Google tells me it isn't. But maybe it's an easy way of making a plug for fibreglass?
