Starter Solenoid issues
JeremyD
Post by JeremyD »
Having been through 4 or 5 ‘Lucas’ push button starter solenoids, I decided to buy a Durite one in August last year. It has now failed just like the others.
All of a sudden after a drive, either immediately after or the next day, the car won’t start. Not even a click. Even the pushbutton does nothing. Of course shorting across the terminals with a screwdriver gets the car started. Replacing the solenoid always fixes the issue for a while.
Does anyone have any thoughts?
TECH396
Re: Starter Solenoid issues
Post by TECH396 »
This answer may seem too obvious but at the risk of sounding silly, Are you using Original Parts?
I've seen nothing but problems with the "Green Box" Lucas Chinese junk.
So, if that what you've been using, try to find some NOS Genuine ones from when they used better materials, and give them a try.
Seems the modern parts are not what they used to be.
Paul H.
Herbert
Post by Herbert »
I would double check all the wires that go into the solenoid. Youve got a short somewhere.
JeremyD
Post by JeremyD »
Rolandino wrote: Sun Jun 06, 2021 6:24 pm I would double check all the wires that go into the solenoid. Youve got a short somewhere.
Surely if it was a wiring problem, the push button would still work, but it doesn’t. Plus they usually work for about 20 starts before failing.
I would love to buy a NOS solenoid, but from where?
I know new Lucas is rubbish quality, which is why I tried Durite !
Andrew1967
Post by Andrew1967 »
Probably best to avoid anything 'brand new' whether Durite or Lucas to be honest, as probably both are made in the same crap Chinese factory.
Chances are, a used original Lucas one or maybe Intermotor will be fine and will go on for years.
NOS ones do come up on the usual site occasionally or maybe someone on here could help if you posted a wanted ad up. ;)
TECH396
Post by TECH396 »
JeremyD wrote: Sun Jun 06, 2021 7:19 pm
Even the Durite stuff is likely made of less quality materials, based on what i can see. All looks Chinese garb to me.
Paul H.
bwaminispeed
Post by bwaminispeed »
You might try taking a failed one apart, and, see what the actual failure is.......just drill out the 4 rivets.....
If there is not even a click, sounds like a break in the wire going to the solenoid coil itself......
Quite possibly an easy fix....
Has thanked: 139 times
Been thanked: 118 times
Good idea there from BWA there. Un-rivet the non working one, take a few photos and let us all have a look.
Are the key operated solenoids - without the push button - as troublesome. I ask in case it's something connected to the push button part
Nick W
Post by Nick W »
bwaminispeed wrote: Sun Jun 06, 2021 8:15 pm You might try taking a failed one apart, and, see what the actual failure is.......just drill out the 4 rivets.....
Don't think you can get into the push button solenoids without cutting them open.
The later square ones seem to be more readily available nos
Up North in Sheffield
Polarsilver
Has thanked: 38 times
Been thanked: 52 times
Post by Polarsilver »
I have Durite Aux Solenoids and not had any issue other than the Rubber Cap will try to fall off .. I found Durite stuff to be ok throughout many years .
Why not send back your "Failed" Durite Solenoid to Durite & see what they say ;)
JeremyD
Post by JeremyD »
Polarsilver wrote: Sun Jun 06, 2021 8:58 pm Why not send back your "Failed" Durite Solenoid to Durite & see what they say ;)
Good idea
indigo
Post by indigo »
I have had a couple of the new green box lucas ones fail. These are the square ones with no push button.
These have one small spade termial for the starter wire from ignition,
And a provision for a second spade termianl molded into the plastic - not sure what this is about.
Drilled the rivets out to pull them apart.
Both have had water in them and rust to the coil, probably from washing uner the bonnet.
On inspection I found they have a small hole in the top of the plastic for the second spade termial.
Water gets in and then rust.
From memory, they have rubber seals where all other parts join to keep water out.
If I needed to use another of these I would seal the small hole and it would probably be good.
Ended up finding and old one and repairing it by pulling it appart and cleaning up the high amp contactors.
Why do I keep so much old crap?
TECH396
Post by TECH396 »
Nick W wrote: Sun Jun 06, 2021 8:50 pm
As a thought. (If originality isn't important to you), why don't you just install a later NOS square one. They do the same thing. Some made late 60s also have a small red push button, which still allows you to bypass the key, just like your original one does. 76766 Lucas #
You can also buy or make the flat metal adapter plate needed to mount it at the same location.
Paul H.
JeremyD
Post by JeremyD »
I removed the Durite solenoid this morning. When you shake it, it has a rattle of something quite heavy. I have sent it back for them to investigate. Poor show really.
Stopped-again
Post by Stopped-again »
Have a look at this one
JeremyD
Post by JeremyD »
Durite have sent a new one which is installed and working. It remains to be seen for how long.
For authenticity I prefer rubber push button type.
