Rear Subframe Alignment
rogerotto66s
Post by rogerotto66s »
Just tried fitting my rear subframe.
The horizontal trunnion bolts fit nicely (subframe toward rear seat).
The vertical trunnion bolts are slightly missaligned as shown in pictures below.
The trunnion on each side needs to move toward the front and the middle to align properly.
This is a replacement subframe with new bushes.
What are my options?
A) different (thinner) bushes
B) tighten nuts to compress bushes.
C) enlarge hole in boot (and use washer)
D) other
Lastly, I assume the rear trunnion bolt is inserted from inside the boot (pointed downward).
Roger Williams
Exminiman
Has thanked: 54 times
Been thanked: 52 times
Re: Rear Subframe Alignment
Post by Exminiman »
My first priority would be to make sure all is straight on the car and on the subframe.
Are both sets of vertical trunnion bolts misaligned by the same amount ?
Presume its not a new subframe or subframe mounting panel not been worked on ?
Has thanked: 138 times
Been thanked: 118 times
Take heart Roger, that's EXACTLY how mine was, even with a replacement Unipart/BMC/BL rear sub frame and boot floor of car after being rebuilt using the datum marks/alignment as shown in the workshop manual. (I rebuilt mine using the datum marks accurately marked on two 6 foot tables)
Personally, I loosened all of the other retaining bolts off, PLUS the rubber bush nuts which made the sub frame slightly more jig-about-able or flexible. From there, with the 6 other bolts and all 4 nuts IN PLACE- but loose, I got the rear right hand bolts in. Then tightened it all up.
I feel that as well as acting as flexible mountings, the rubber bushes will easily be able to accept the very slight variation. It has done. I stripped it to replace the rubber bushes a couple of summers ago and they were perfect - so I put them back!!
Andrew1967
Post by Andrew1967 »
Sometimes you do need a Phillips screwdriver or similar in one hole to just pull the trunnion into line.
That’s certainly not the worst I’ve seen.
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Post by AndyPen »
I have just done mine and had similar alignments. The rubber does give a bit and the set of posi screwdrivers were invaluable.
Something you don't hear about much is that in the factory they trimmed down some of the rubber bushes slightly. I only saw them doing it on the inside when I visited the production line, and was surprised enough to ask why?
The answer was, with tolerances of plus or minus 1/4 inch, it means there can be half an inch difference sometimes.
The reality of mini building!!!
111Robin
Been thanked: 17 times
Post by 111Robin »
One word, podger, your alignment tool of choice, the longer the better to give good leverage against the rubbers.
rogerotto66s
Thanks all.
I guess “misery loves company” applies to some degree!
It is a replacement subframe and the mounting panel has not been worked on.
Both trunnions do appear to be misaligned by the same amount, both front/back and left/right.
Left/right both trunnions need to go toward the middle.
I will try to align using the screwdriver and then if need be compress/trim the trunnions slightly.
Front/back both trunnions need to go front.
If the left/right adjustments also solve this front/back alignment I am done (hopefully).
Else I will elongate the boot hole slightly and use a washer in the boot.
If all goes well ... I may have the “S” back on the road by end of summer!
This would be the first time I will have driven the “S” since I purchased it in 1993 ...
... and the first time it would be back on the road since 1980 ... if all goes well!
... one small step for man ... one giant leap for me (not really a techie car guy)!
Roger Williams
AndyPen
Post by AndyPen »
I do recall having the trunnion shoulders machined back at the heel board end on one car, my wife's - as they bottomed out in the subframe and stopped us compressing the rubber any more. That was way back in the early 90s mind you, so they've only lasted nearly years ;-)
rogerotto66s
Subframe is in!!
On my first attempt I inserted the front bolts but had problems with aligning the boot trunnion.
On the successful attempt I started with the boot bolts and then inserted the front bolts.
Not sure what the difference was.
Not sure but possibly I had the boot trunnions on the wrong way.
... onto the front subframe.
Roger Williams
rogerotto66s
Had to drop the subframe to re-route the battery cable properly.
All looks good now.
Roger Williams
AndyPen
Post by AndyPen »
Looking good - glad its gone in ;-)
TECH396
Post by TECH396 »
rogerotto66s wrote: Fri Jun 04, 2021 8:49 pm Had to drop the subframe to re-route the battery cable properly.
All looks good now.
Don't forget to put the hydro line insulating sleeves on.
Paul H.
