Mini4Ever wrote:PS: Have a complete Inno 1001 engine for sale as well as a good 12G295 head and a pocketed 998 Mk I block with +40 flat top pistons (circlip fit).
With the circlips holding the gudgeon pins in, I was given a tip once to make sure the gap is at the top, and loctite the circlips in, to stop any chance of them popping out at about 7000rpm, when you decide to do about 110mph/175kph down a hill, with the wind behind you!. But can't remember what loctite code it was that I used.
And another tip I had from the same person was to put a thin smear of hermatite gold non-setting gasket sealant on the block side of the gearbox and flywheel housing gaskets, because it allows movement between the iron block and alloy gearbox and flywheel housings with their different heat expansions, so prevents oil leaks from them, even though you think being bolted together won't make any difference. Never ever had oil leaks from here, but did from diff output shafts though. But changing their rubber seals fairly regularly stopped that. The problem with diff oil leaks is the brass bearings wearing out.
edit- whoops, hermatite gold, not green
