Could anyone pls enlighten me, what the approx dimension of the mounting plates of a JA 3-point rollcage are and where they are attached to the body in the rear bins? One or two photos would be very helpful too, I suppose.
If you ask yourself why, because I want to reproduce one from solid drawn thick wall 32mm tube.
Position/Dimension of John Aley 3-point rollcage mounting plates
- MiNiKiN
- Has thanked: 86 times
- Been thanked: 31 times
Re: Position/Dimension of John Aley 3-point rollcage mounting plates
Brian Purves sells them for not that much. Is it worth it?
- MiNiKiN
I bought the clamp of him.
Is it worth it
Is it worth it
- I rather not imagine what the cost of sending this item from UK to Austria would be
- I will improve the shape to better fit the Mk3 Innocenti bodyshell
- I will also add a bracket that connects the rollbar to the seat belt mounting on the b-pillar
- Has thanked: 15 times
- Been thanked: 16 times
The fixing plates on the two side legs of my John Aley are 100mm x 50mm.
- MiNiKiN
Thanks Steve
