Boot clips 1964 mini
- twodoor64
Re: Boot clips 1964 mini
The repro clips aren’t as good as originals the steel is more malleable and not as hard, they can rarely be used more than once, so just make sure you get it right first time, I usually fit the clips one at a time and just continue around the bootlid until they are all installed, they are easy to push in but may need a little bending to fit securely
- twodoor64
I have done both my cars after bootlid was fitted,I only fitted seal with tape when trial fitting bootlid fit prior to paint.
- colonel mustard
From memory I put the clips on the seal first and then pushed the lot into place, otherwise getting the seal on after the clips have been installed is not good.
Make sure you start at the bottom of the lid and work around.
Hope that helps?
Hope that helps?
- Been thanked: 32 times
The clips are a total pain in the arse .... I use contact adhesive . .... ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- twodoor64
- colonel mustard
I would go clips and used vasoline to help push the clips in. They are not that bad really.
- Has thanked: 141 times
- Been thanked: 121 times
I say clips but as said before, start at the bottom centre. Clips into rubber at approx place, a bit of vaseline or KY Gel (won't affect the rubber) and clips will slip into greased hole like a well worn sea boot! But before you do, might I suggest that even before you bolt the boot lid in place, you flood the internal (if double skinned) or outer edges internally with Supertrol 001 - or whatever your choice of rust inhibitor for a day or so, so that it works its way between the double skins.
Amazingly, or maybe not as we're talking about BMC.BL and MG-ROVER, this is where I found out that from day 1 of production right up until the very last day - as I found on my 2000 RCSport-5, BMC et al, didn't paint under the boot lid hinges. Not the boot lid nor the lower panel.
- twodoor64
Peter.... Great tip. (Supertrol 001). I once stored a sub frame on concrete and the moisture rusted the bottom out.... Lesson learned.
When I fit the clips, I use a flat screwdriver, put the clip on the seal an d figure out exactly where it will be placed to align with the hole. Then put the screwdriver in above the flat side and tap the screwdriver shank till the clip is home.
- twodoor64
