Mk1 wiper outer tube
- johnv
could anyone please tell me the approx length of the first tube? (the one with the nut on it) thanks
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
- Chewie Baker
Re: Mk1 wiper outer tube
does this help?
- johnv
yes it does .. the Somerford one is 190 end to end not taking the curve into account .. yours looks to be 170ish which is more in line with my expectations. I've ordered the Somerford one but I don't think it'll fit!
Is there a reason you can't cut it off and flare one end where you need it? On race cars we delete one wiper box, the hole in the scuttle and run one wiper in front of the driver only. Steve (CTR)
- Has thanked: 142 times
- Been thanked: 122 times
While I was restoring mine and my wifes, I just made up my own outers to suit! I had a long length of the tube, used a simple and cheapo flaring tool which I've still got and soft soldered a brass ferrule onto the nut-to-motor end. Still working as good as new
(Thinks..., the ferrule was a plumbers off the shelf bit from that small-bore heating pipe that used to be all the rage)
- Been thanked: 52 times
As has been pointed out you can make your own with a pipe flaring kit and 5/16" OD steel pipe.
