some more problems with my new engine, the gearbox doesn't seem to work properly
We built it with the following species
-22G1128
-ST 4 sync S/C gearbox
-KAD pinion housing
-MED S/C drop gear
-MED Ultralight flywheels
I checked the gearbox extension, everything is ok and greased, I set the clutch arm properly, master and slave cylinder are ok
I was wondering if the KAD pinion support hold properly this fork? as the standard pinion housing have. big flat surface
inside it's very close but we slightly modified the pinion housing for clearance
Thank you for your help guys
The gears are hard to engage even with a shut off engine, and the 2nd gears scratch if you don't make an heel and toe.
