I just start my new engine and achieved a few kilometers with the followings species
1293
Modified head
Med gearbox, and Med flywheels
SW5
KAD RACE oil pump (maybe the cause of my problems)
CSI swiftune dizzy etc..
Oil relief valve fitted with S Spring
S oil cooler
The engine works very well but the oil pressure is not as good as expected
For example I achieve 30 miles yesterday with an oil cooler cover, the pressure was 60 PSI at 4000 rpm and 15/20 at 1000rpm, the weather wasn't too cold, about 10 degrees
I decided to remove the oil cooler cover and 1 mile after the pressure was so much better 25 psi at 1000 Rpm and 75/85 at 4000 rpm
I'm wondering what was the problem,
Oil overheating that could lower the pressure?
Oil pump ? I know that the race oil pump are supposed to give less pressure at low rev
I checked everything but I would like your advise before to pull the engine out as it's brand new there no reason to have failure
One of my friend told me that the S relief valve spring could cause oil pump gasket failure?
