Next project - ‘62 997 Austin Cooper
GraemeC
Post by GraemeC »
Just done a rocker cover - preheated in the oven at about 80 deg for about 10 minutes, sprayed and then returned to the oven at 180 deg for another 10-15 minutes.
Came out well, but the house stunk for about 4 hours (or I got used to the smell by then :lol: )
MiNiKiN
Has thanked: 17 times
Been thanked: 9 times
Post by MiNiKiN »
I just spray one or two thick layers on and then give it a good roasting with the heat gun. Always works.
Bart Smith
Post by Bart Smith »
Yep, heat. I shoot it and use a heat gun.
colonel mustard
Post by colonel mustard »
another one for two thick layers and blasted with the heat gun, you can watch the transformation before your eyes! :P
Dearg1275
Post by Dearg1275 »
Thanks everyone for your suggestions. And YES, I’ve cracked it and got some cracking crackle.
I used the heat gun technique. I can do that in the shed and avoid complains about a strangely smelling evening meal.
kevs 1961 mk1
Post by kevs 1961 mk1 »
top work well done mate , looks ace
long time gone
roger mcnab
Post by roger mcnab »
hi d
i used to use mums oven to heat the old triumph crank cases to remove old bearings she used to give me some funny looks but never said anything
could not get away with that now wife would have my throat but have other ways now like gas bbq
car is coming along nicely keep up the good work making slow progress with the clubman will get the block bored next month so long as nothing unexpected occurs
cheers roger mc nab :lol: :lol:
Dearg1275
Post by Dearg1275 »
The carpet is down and the colour goes well. It’s looking more like the front room than the inside of a mini. I just have to check over the electrics then we can see if I can get some oil pressure. Can’t start the engine yet as I need an exhaust system.
I feel I should add an after market gear knob for that period feel. Any suggestions?
timmy201
Post by timmy201 »
Sorry if I’ve missed it, but what steering wheel are you going to be using? It might be nice to match the gear knob to the steering wheel - wood/leather etc
Dearg1275
Post by Dearg1275 »
I haven’t thought as far as a steering wheel. It rather depends on what I get for my birthday!
Polarsilver
Been thanked: 17 times
Post by Polarsilver »
Well you have done a great job & me surprised me how quick the turnaround .. get your Harry Moss Air Horns fitted they will put a :) on your face.
Andrew1967
Post by Andrew1967 »
Looks great David.
Did you cut the carpets yourself ?
Dearg1275
Post by Dearg1275 »
Andrew1967 wrote: Fri Jan 22, 2021 10:23 pm Looks great David.
Andrew, yes I cut the carpet myself. I did the back to a paper template and wasn’t too happy. For the front I measured where the gear lever boot would go and cut in from a straight edge for that (a paint tin did nicely). I then worked from there with a sharp carpet knife under trimming to start with and refining later. It’s still a little oversize to left the carpet settle. I won’t fit the carpet clips until it’s had a chance to warm up.
I used a pvc backed carpet from Segal from their Jaguar range. This was quite useful as where the starter button bulge is, I warmed the backing with a hot air gun and was able to get a bit of shape into the carpet by holding it firmly in place as it cooled. It took a few applications to get much of a result but it has helped the carpet to sit a bit better. The PVC backing also makes for very clean and tidy cuts.
Dearg1275
Post by Dearg1275 »
Just working through a few crazy ideas. Heated screen wash.
Hopefully the hose routing will keep the screen warmer too. It also increases the coolant volume a bit (which is why BL went to 5/8 hose rather than half inch). I’m not finalised on the hose routing to the tap yet until the servo is in.
kevs 1961 mk1
i did this very thing back in the 70s ,the washer pipe round the heater supply pipes works well ,the only thing is the windscreen washer jets will still be frozen a bit first thing on a frosty morning but once the engine has warmed up ,the heat transfers up the washers pipes and frees it off , cheers kev
long time gone
Dearg1275
Post by Dearg1275 »
Today was not the day for messing about with sheet metal. Too cold, but none the less I was bored so had a go at a solution for the air filters. Feeling my way a bit but made a useful start.
Dearg1275
Post by Dearg1275 »
Air box finished. And it gives much more room to get at things.
jay weinstein
Post by jay weinstein »
That's really nice..good work !
Dr.Mabo
Post by Dr.Mabo »
Wow, thats a great job and a clever airfilter solution for the twin H4s
I like that.
so long
the Doc
My previous project:
roger mcnab
hi d
that is a very neat air box that you have worked out a little insperation and a few odds and ends is all it needs great work and car is looking great as well
cheers roger mcnab :idea:
