1098 Crankshaft
- diz
1098 Crankshaft
Are all 1098 crankshafts the same spec? - I’m thinking of fitting a 1098 crank (and pistons) to a 998 block and want to make sure I get the right one.
Appreciate any info.
Thank you, Diz
Thank you, Diz
- Costafortune
- Has thanked: 32 times
- Been thanked: 38 times
Re: 1098 Crankshaft
Pretty much yes. Pre 65 had a thin tail for the small primary gear but anything since the dawn of time (or the Allegro) will be the same. There wasn't an A+ 1098 either.
- Has thanked: 187 times
- Been thanked: 65 times
- diz
Re: 1098 Crankshaft
Many thanks for the information.
I suspect availability will determine what I end up using but to help me can you advise what regrind size is acceptable before strength is unduly compromised?
The engine will be for road use only and I intend to build with flat top pistons, 295 head, SW5 cam and HIF38 carb.
Thanks, Diz
Thanks, Diz
- Costafortune
Re: 1098 Crankshaft
Any evidence of that? Part numbers as opposed to heresay.bwaminispeed wrote: ↑Mon Nov 30, 2020 5:25 pm The ones in the MG 1100 were EN16 spec, and, crossdrilled..........
- Costafortune
Re: 1098 Crankshaft
I doubt that. I used to service a 1981 Allegro 1100 on an W plate that was most definitely an A Series. These were replaced early '81 by a 998 A+
The A+ was completely different. Everything was changed. BL would not have spent money making an engine they were not fitting to any production cars.
The first car to use an A+ engine was the Morris Ital in mid 1980. The A+ block was however trialled in a handful of cars in 1979-80 including some 998's and therefore very possibly 1100's. They are not A+ engines however.
- Costafortune
Re: 1098 Crankshaft
You think wrong. The 1275GT used an A Series 1275 to the very end.bwaminispeed wrote: ↑Mon Nov 30, 2020 7:06 pm I think the late production Clubman GTs had those motors.....
- 850man
Re: 1098 Crankshaft
Any evidence of that? Part numbers as opposed to hearsay.
Restoration Specialist - https://www.facebook.com/linkautomotive
- Costafortune
- Costafortune
Re: 1098 Crankshaft
10 thou really. Tim at Minimail had a few new ones in grease paper but that was several years ago.diz wrote: ↑Mon Nov 30, 2020 7:29 pm Many thanks for the information.
Thanks, Diz
It's a nice conversion and you can run a decently tall final drive such as a 3.1 or 3.2 with ease.
Re: 1098 Crankshaft
Code: Select all
For a brief (and perhaps, obscure) period there was an A+ 1100, in 79 and 80.
a friend here bought a lot of parts from UK long time back and there was a 1100 A+ block engine with 10H engine number tag .
Of course tag might had been changed... by the time he was told the engine came from a 1100 Special.
just did a quick search... and there is one 1100 Special advert, low mileage... with A+ block. No clue how genuine this engine/car is.
Nice car BTW.
https://car-from-uk.com/sale.php?id=54323
Luis
Re: 1098 Crankshaft
You are correct, up to 1965 the 1098cc MG 1100 had an EN16T cross-drilled crankshaft. They lost it when the Riley Kestrel and Wolseley 1100 came out in late 1965 and all used the standard 1098cc crankshaft. I've never seen an early MG 1098cc engine without the cross-drilled crank. The parts number are in the book "Anatomy of the Classic Mini"bwaminispeed wrote: ↑Mon Nov 30, 2020 5:25 pm The ones in the MG 1100 were EN16 spec, and, crossdrilled..........
Alan
Re: 1098 Crankshaft
I've a friend who bought a Mini 25 Special from the Patrick Collection and I replaced the clutch in it the other week. I'm sure it is totally original and it has 22G1832 gearbox and pre-verto clutch assembly. It is 1979 built and has a 1098cc A+ engine which was a surprise to me.LuisM wrote: ↑Tue Dec 01, 2020 10:12 amCode: Select all
Nice car BTW.
Luis
Alan
Re: 1098 Crankshaft
I’ve always maintained there is no logic to what you find in BLMC / BL timelines. As I said above that original 1979 Mini Special has the 1098cc A+ engine and earlier running gear. I also work on a very original 1980 1098cc Mini Clubman and it has the Pre A+ motor from new. The Clubman is 14 months younger than the Mini Special and this just goes to prove the point.
Alan
Alan
- Been thanked: 10 times
Re: 1098 Crankshaft
My 1980 GT was A+ engine and gearbox, 1040 laygear. I got car from original owner in '85, it had not had an engine swap.Costafortune wrote: ↑Tue Dec 01, 2020 8:54 amYou think wrong. The 1275GT used an A Series 1275 to the very end.bwaminispeed wrote: ↑Mon Nov 30, 2020 7:06 pm I think the late production Clubman GTs had those motors.....
- diz
Re: 1098 Crankshaft
Thank you. I'll contact Tim and also post an ad in the wanted section to see if anyone can helpby Costafortune » Tue Dec 01, 2020 9:01 am
- Costafortune
- Costafortune
Re: 1098 Crankshaft
Sorry, I meant they didn't have 1100 engines as was suggested. The A+ seemed to go into series production around May/June 1980OzOAP wrote: ↑Tue Dec 01, 2020 11:08 amMy 1980 GT was A+ engine and gearbox, 1040 laygear. I got car from original owner in '85, it had not had an engine swap.Costafortune wrote: ↑Tue Dec 01, 2020 8:54 amYou think wrong. The 1275GT used an A Series 1275 to the very end.bwaminispeed wrote: ↑Mon Nov 30, 2020 7:06 pm I think the late production Clubman GTs had those motors.....
