As I often prefer to rather build than buy, I thought I might have an attempt on building my own Quickshift.
What are the requirements:
- I want the gearstick to be roughly 15cm longer and bent backwards, so it sits closer to the steering wheel
- For obvious reasons then the lower lever, down the ball joint shall be longer so I wouldn't create an 'Extended Travel Shift'
- Rumour has it the ADO16 remote stick is longer - the lower lever too?
- Maybe a pudding stirrer (aka magic wand) - what's the length of the lower part on this?
Your thoughts would be appreciated.
Marcus
