Steering column wiring
rogerotto66s
Post by rogerotto66s »
What is the routing to connect the steering column wires to the main loom behind the heater?
I know they connect via a 5-way connector.
Do the wires just hang under the pedal box?
A picture would be great.
Looks like the steering column (and wire connections) are done before the heater is installed.
Roger Williams
rogerotto66s
Re: Steering column wiring
I understand the wiring runs under the pedal box.
Apparently there is a clip that attaches the wiring to the pedal box.
See #25 below.
Roger Williams
