Engine bay brake/clutch pipes for 65 S
Andrew1967
Post by Andrew1967 »
Anyone able to post up some pics of correct shape and positions of the brake pipes in the engine bay ? I've had a look in the two usual books, but nothing really clear.
Also, does the clutch pipe come out of the master cylinder and go straight down to the hose with a wide radius or with a narrow radius and then has a set in it further down to bring it in line with the hose ? I've seen both types on cars ...
This is how I did it on 9748KO but not sure how accurate it is.
AndyPen
Has thanked: 18 times
Been thanked: 50 times
Re: Engine bay brake/clutch pipes for 65 S
Post by AndyPen »
I seem to recall Winnaby has the plans for the pipes???
OGW 1082
Post by OGW 1082 »
Hi Andrew,
I 've a photo of UK spec from a 1965 Road test.
Regards,
Glen
Andrew1967
Hi Glen,
Thanks for the pic .. interesting that the servo pipes go over the top of the servo. I've seen pics like that and also ones that go underneath, in a similar fashion to how I did them on 9748KO.
See what else is forthcoming :?
Andrew
aga2
Post by aga2 »
Hi Andrew
This may also offer some help..this is a 66s not sure if they differ..
Andrew1967
Thanks for that pic :)
From a couple other period pics I've seen, it seems that the earlier cars with the short (finish at the triangular reinforcer) air hose have pipes over the servo and those with the full length hose go under the servo.
aga2
Post by aga2 »
Another from different view..that may be correct Andrew, I'm not sure, hopefully others may be able to advise aswell
Andrew1967
Yep, hopefully others can confirm :)
Can see from that pic the upper shape of the pipe from tee to brake light switch union too.
bwaminispeed
Post by bwaminispeed »
Noticed that brake line right away too, not like any I have run across......
That vacuum hose routing is also like nothing I have seen before either....
OGW 1082
Post by OGW 1082 »
Hello Andrew,
I found another Road Test photo August 1964. I think you are correct. The lines go behind the booster when the long air tube is used.
Regards,
Glen
Dearg1275
Post by Dearg1275 »
Gareth Brandt
Post by Gareth Brandt »
Glen, I think that is a pre hydro car. This is my april 64 1071 S, pre hydro.
Andrew1967
Thanks for the input thus far everyone.
It does seem that where the long wait hose was employed the pipes went underneath and around the side of the servo but on the short hose type, they went over the top.
Its a shame that neither The Bible nor the Factory Original books show the short air hose.
Andrew1967
I've had it on good authority that it does seem that the pipes go over the top on the short hose cars and underneath/around the side on the long hose cars.
As an aside, does the original S servo have three mounting studs on the diaphragm cover or two ?
Herbert
Post by Herbert »
But from the picture it's a left hand drive car!
AndyPen
Post by AndyPen »
Just found this - most likely taken off this site a couple of years ago???
Looks like the change point was when the PCV valve came in mid 64 ??
Andrew1967
HOY is a March 65 and has the short hose, finishing at the triangular reinforcer.
It’s the route of the pipes on these cars I’m really interested in as all the pics I’ve seen of these cars have had the pipes over the top, as per the 1st period pic that Glen posted up on page 1 and as per aga2’s pics.
OGW 1082
Post by OGW 1082 »
Hi Andrew,
2 Mounting studs on mine 1967
Regards,
Glen
Been thanked: 10 times
A fairly good view of a short pipe 65 S.
Ok, its been buggered about with a bit, but I believe the pipe positions are still more or less correct.
Andrew1967
Thanks for posting that Mark.
I’ll go along these lines but will try to make it look a bit neater than the examples shown otherwise Rich will be on my case again :lol:
