Flip cap removal
Aginley
Has thanked: 5 times
Flip cap removal
Post by Aginley »
Help wanted on how to remove this cap.
Wanting to do a nice restoration job on the planet rocker cover so need to remove the cap. I presumed it has a brass coller pressed in and the cap screwed onto the coller. I’ve tried to unscrew but it seams very tight
Don’t want to damage trying incase it’s not a screw in type.
Any advice appreciated
Been thanked: 10 times
Re: Flip cap removal
:lol: WD40 :?: Or try to heat it up a bit, maybe that will do the job :?:
Kees
Aginley
Post by Aginley »
Is it a screw in type though? Not the whole thing pressed in?
Ta
Oneball
Has thanked: 10 times
Post by Oneball »
I’ve got what looks the same both inside and outside on the Vette and it screws on.
Aginley
Post by Aginley »
Turns out it was a screw in! Just needed some heat!
Few hours of faffery later I’m very pleased with the results
Time Bandit
Post by Time Bandit »
That looks spot on, you've done a great job on it! 8-)
Mike
colonel mustard
Post by colonel mustard »
Hi Al
Did you mask the highlights off?
Aginley
Post by Aginley »
colonel mustard wrote: Sun Nov 15, 2020 2:45 pm Hi Al
Yes and used a scalpel to do the intricate bits. Took ages :D
irlmin
Has thanked: 31 times
Post by irlmin »
Aginley wrote: Sun Nov 15, 2020 4:10 pm
Was worth the effort I am sure , looks brilliant , G
