Crank shaft thread
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Crank shaft thread
Post by woodypup59 »
What size is the screw thread in the crank to hold the flywheel on please.
iain1967s
Been thanked: 7 times
Re: Crank shaft thread
Post by iain1967s »
5/8" x 16tpi Whitworth form
Louis
Post by Louis »
According to the Guessworks site, it is 5/8" 16 TPI
http://www.guess-works.com/Shop/Parts/d ... htm?id=494
woodypup59
Thanks - if anyone has one, can you confirm the o/d of the tap over the cutting edges.
GraemeC
Post by GraemeC »
bwaminispeed
Post by bwaminispeed »
So, that would make it a 16-16 tap???? :o
251 ENG
Post by 251 ENG »
Its 5/8 x 16tpi whit form .
It's a special non standard thread size
iain1967s
Post by iain1967s »
Easily confused with a 5/8-16 SAE tap (more common here in USA), but that has a 60° angle thread form, so will under-cut the 55° of the Whitworth form. Blue loctite is your friend if someone else has already used an SAE tap...
OzOAP
Been thanked: 10 times
Post by OzOAP »
I have taps available in my facebook shop if anyone needs one.
woodypup59
Does that make it the same size as the bypass hose spigot in the head ?
GraemeC
Post by GraemeC »
Yes - both ends of the crank and the bypass spigot are all this thread.
woodypup59
Great - its worth buying one then.
