Starter motor 'running on'!
davidmuir
Has thanked: 18 times
Post by davidmuir »
Hi,
Why would the starter motor 'run on' after starting?? Took the original off and cleaned shaft etc and refitted-no difference! Put on spare and it does the same! (when I say 'runs on' , it's like the pinion is taking its time going back).
wantafaster1
Has thanked: 17 times
Been thanked: 11 times
Re: Starter motor 'running on'!
Post by wantafaster1 »
Sticking solenoid
davidmuir
Post by davidmuir »
Thanks!- will try and dismantle!
davidmuir
Post by davidmuir »
Ahhhhh- obviously you're not supposed to dismantle them! I hear the new ones are suspect- ?best source?
Are all the 'Lucas' ones on Ebay fake?
Nick W
Post by Nick W »
Have you got the correct pinion ..Inertia or pre-engage to match your flywheel?.
Up North in Sheffield
Andrew1967
Post by Andrew1967 »
davidmuir wrote: Sun Sep 13, 2020 4:36 pm Ahhhhh- obviously you're not supposed to dismantle them! I hear the new ones are suspect- ?best source?
Original orange boxed ones should be fine. Its the green Lucas boxed ones to avoid.
A correctly working used original is sometimes the best way forward.
bwaminispeed
Post by bwaminispeed »
I take them apart all the time, just drill out the rivits, and, re-assemble them with nuts n bolts.......
davidmuir
Post by davidmuir »
no rivets, it seems just to be crimped-tricky! (original 1967)
bwaminispeed
Ah, the round one, keep forgetting about that........
